Patrick Tresch Posted December 22, 2021 Report Share Posted December 22, 2021 Greatings from Niger. Here a lot of wind and dust. But some of the most beautifull places I've seen. CCM8, CCM41, Cinela Léo, Sonosax M2D2 on the Sony A7s3 camera Quote Link to comment Share on other sites More sharing options...
Sebben Posted March 19, 2022 Report Share Posted March 19, 2022 On 12/22/2021 at 1:04 PM, Patrick Tresch said: Greatings from Niger. Here a lot of wind and dust. But some of the most beautifull places I've seen. CCM8, CCM41, Cinela Léo, Sonosax M2D2 on the Sony A7s3 camera How do you attach the Sonosax to your camera rig? Quote Link to comment Share on other sites More sharing options...
Barry M Posted March 19, 2022 Report Share Posted March 19, 2022 That's Patrick's fine design and 3D print, I think. See up-thread: It looks like the 3D printed accessory shown in their video of DSLR use, about 2:19, so perhaps that's what Sonosax provides in the mounting accessory files they mention on their M2D2 page. The pictures are of a different bracket, and I can't actually see a link there at the moment, so contact Sonosax if you don't find them. https://sonosax.ch/product/sx-m2d2/ Quote Link to comment Share on other sites More sharing options...
Patrick Tresch Posted March 22, 2022 Report Share Posted March 22, 2022 Hello, I hope you can download it here. I use it with this one https://www.smallrig.com.de/products/smallrig-15mm-rod-clamp-mit-cold-shoe-1597?variant=12549833752637¤cy=EUR&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gclid=Cj0KCQjw5-WRBhCKARIsAAId9FmYBXwWCq_rMM2nYmJHqz6Mv3RAiDJ5vJ0d1uK5RisGnbUnCvQZRcQaAkNXEALw_wcB See you Patrick M2D2_ETRIER_PLASTIC.STL Quote Link to comment Share on other sites More sharing options...
Philip S89 Posted April 8, 2022 Report Share Posted April 8, 2022 Greetings, I’m not a professional so forgive me. I am looking into buying a video camera that I will be able to run the m2d2 into it and get its good sound. Will the m2d2 sound file be recorded onto the the camera’s SD card? Will the sound be linked to the video file? If the camera has hdmi out or sdi out will I be able to live stream with the good sonosax sound? Thank you. Quote Link to comment Share on other sites More sharing options...
Trey LaCroix Posted April 8, 2022 Author Report Share Posted April 8, 2022 2 hours ago, Philip S89 said: Greetings, I’m not a professional so forgive me. I am looking into buying a video camera that I will be able to run the m2d2 into it and get its good sound. Will the m2d2 sound file be recorded onto the the camera’s SD card? Will the sound be linked to the video file? If the camera has hdmi out or sdi out will I be able to live stream with the good sonosax sound? Thank you. The M2D2 will not record a file. It is a very high quality preamp and A/D converter that will pass either analog or AES digital audio to a recording device, like a production sound recorder or a camera. If the camera has AES inputs you can bypass the analog input stages of the camera and keep it in the digital realm. It should be untouched as it comes out of the SDI or HDMI signal. I'm not sure you will notice a real difference from the sonosax if it's going to be live-streamed. I imagine the subtle nuances of the preamp will get lost in the data compression required for streaming. Quote Link to comment Share on other sites More sharing options...
Philip S89 Posted April 9, 2022 Report Share Posted April 9, 2022 (edited) On 4/7/2022 at 11:58 PM, Trey LaCroix said: The M2D2 will not record a file. It is a very high quality preamp and A/D converter that will pass either analog or AES digital audio to a recording device, like a production sound recorder or a camera. If the camera has AES inputs you can bypass the analog input stages of the camera and keep it in the digital realm. It should be untouched as it comes out of the SDI or HDMI signal. I'm not sure you will notice a real difference from the sonosax if it's going to be live-streamed. I imagine the subtle nuances of the preamp will get lost in the data compression required for streaming. Thank you for you answer. So you are saying I can input into the m2d2 a high quality stereo pair, and route this signal to the m2d2 AES output? Which will then carry an AES digital signal into a camera that has an AES audio input? I thought the AES out on the m2d2 is made only for outputting the AES input. I didn’t know you can plug in analog and output it digitally through the AES out. Also, I have no idea how an AES input on a camera looks like. The cameras I’ve been looking at have either mini xlr (taking line/mic analog signal) or a 3.5mm jack. So the mini xlr for example on the black magic (pocket) will take a line level from the analog output of the m2d2, or a 3.5mm from the usb of the m2d2 (is this correct?) My purpose in connecting the m2d2 into a good video camera is twofold: -livestream (which will be compressed and shitty quality-i don’t really care) -but also, recording it at the same time (before it feeds into the live stream) without loss of the data. This file essentially will have an excellent video, AND an uncompromising sound from high-end mics that passed through the m2d2. This is to record and live stream classical music recitals. Edited April 9, 2022 by Philip S89 Spelling Quote Link to comment Share on other sites More sharing options...
Philip S89 Posted April 10, 2022 Report Share Posted April 10, 2022 Ok I realised that I can’t afford a video camera that has an xlr aes input. So here is an idea for a setup (please tell me if it’s doable): A stereo pair of 48v mics going into an m2d2 and out through the USB into a computer. Independently from that, a video feed will go into the same computer. Both feeds will go into OBS, where I will sync them and livestream. At the SAME time (for backup!) the video feed will be recorded onto the camera’s sd card (or something other than the computer), and the stereo signal from the m2d2 will not just go out of the usb into the computer, but also it will go out through the AES out and into an AES input of a Lectrosonics SPDR recorder. can this be done?? Quote Link to comment Share on other sites More sharing options...
Patrick Tresch Posted April 10, 2022 Report Share Posted April 10, 2022 Why don't you record the USB signal on your computer and use the M2D2 as an audio card? On the M2D2 you could use a delay to synch with the video signal for streaming if you use a Blackmagic Atem switcher. In relation of compression you have to test wich is the best route to go for streaming (youtube, facebook, ... ) Quote Link to comment Share on other sites More sharing options...
Philip S89 Posted April 11, 2022 Report Share Posted April 11, 2022 The ATEM switcher will give me option for a few cameras. So I will have m2d2 analog out into the ATEM via the 3.5mm jack, and at the same time, out of the m2d2, I will have an AES out into a dedicated recorder or a USB out into an ipad/iphone/computer for backup audio and high level audio recording. And the ATEM will be connected to the computer live streaming. Does this sound right? And If I need one camera the ATEM is pretty much redundant i think Quote Link to comment Share on other sites More sharing options...
chrismedr Posted April 11, 2022 Report Share Posted April 11, 2022 the M2D2 is a lovely device, but in your case scenario it seems to me that you should first think about your setup in general before you select specific components. like what is the room situation? how many people? how many cameras? voice or music? how high is your budget? etc. usually mic placement is the most important aspect anyway. Quote Link to comment Share on other sites More sharing options...
Philip S89 Posted April 11, 2022 Report Share Posted April 11, 2022 Thank you. I have experimented with different setups extensively, and I’ve been getting nice results with VERY basic equipment that I have (CM4 and a zoom f6): im upgrading my equipment, to get better sound quality, and start live streaming with 1 camera only. I am trying to order the m2d2 from noyzboyz in Amsterdam, because it’s the best price I have found. I really wanted to get the Nagra 7, but I decided I will invest in good mics instead. Quote Link to comment Share on other sites More sharing options...
chrismedr Posted April 12, 2022 Report Share Posted April 12, 2022 10 hours ago, Philip S89 said: I really wanted to get the Nagra 7, but I decided I will invest in good mics instead. yes, that sounds like a good plan. can't go wrong with some schoeps or sennheiser MKH mics, but if you can it's probably worth renting a few different options before you buy to see what you like best in your scenario. Quote Link to comment Share on other sites More sharing options...
Jorel Ayer Posted May 23, 2023 Report Share Posted May 23, 2023 Hey everyone. I'm thinking of building a small rig for field recording. I'm considering the m2d2 or the mixpre6. I think the sonosax will have a better sound but the mixpre is also a dedicated recorder. I don't need all it's features for field recording except maybe more pre's for flexibility. Is there anyone here using the m2d2 as a pocket recorder recording to his smartphone ? How is it ? Thanks! Quote Link to comment Share on other sites More sharing options...
petersont Posted May 24, 2023 Report Share Posted May 24, 2023 On 5/23/2023 at 4:38 PM, Jorel Ayer said: Hey everyone. I'm thinking of building a small rig for field recording. I'm considering the m2d2 or the mixpre6. I think the sonosax will have a better sound but the mixpre is also a dedicated recorder. I don't need all it's features for field recording except maybe more pre's for flexibility. Is there anyone here using the m2d2 as a pocket recorder recording to his smartphone ? How is it ? Thanks! There is another extensive thread on Gearspace you might enjoy: https://gearspace.com/board/studio-stage-mobile-amp-location-equipment/1294096-sonosax-sx-m2d2-how-practical.html. In short, after some very high praise for its preamp quaity from a few big label pro classical recordists, it seems using with the iPhone is easily done - Sonosax actually sells the proper cables and some use the Apogee app MetRecorder. But I think that if it was me heading off to who knows where with the smallest kit possible, I'd also pack a tiny MixPre3ii in my waist bag just cuz... Quote Link to comment Share on other sites More sharing options...
allensavage Posted February 21 Report Share Posted February 21 hey guys, I am not a professional recordist yet taking it as a hobby. I brought m2d2 as my SWISS KNIFE to record, transfer, mix and anything related to daily sound, and hoping for another couple of usb tracks just like SD mixpre6 instead of only 2 now, cause I found it useful if I could use it as a soundcard to loopback another stereo track, so I could have that the VSTs, like F6 Nx etc, work for monitoring. Any thoughts about this? Quote Link to comment Share on other sites More sharing options...
EinF Posted Thursday at 10:14 PM Report Share Posted Thursday at 10:14 PM Pardon forum lords if I've missed this answer: has anyone landed on a low profile usb-centered audio recorder to pair with the M2D2 ( other than the established iphone/lectro SPDR options). Of course you could pick up a zoom F3, but thinking even that seems unnecessary as it doubles up functions. Maybe I'm dreaming, but I'd assume there would be something else in this influencer-video era of always recording. Quote Link to comment Share on other sites More sharing options...
The Documentary Sound Guy Posted Thursday at 10:42 PM Report Share Posted Thursday at 10:42 PM There's always the Nagra Seven. Which also doubles up functionality, but at least its preamps are better than a Zoom. I'm not totally sure what you mean by USB-centred audio recorder. You mean a recorder that accepts a USB interface as an input? I don't think it exists ... there's no reason to make one when a phone or a laptop can do the job just as easily (with no difference in quality, and probably a minimal difference in convenience). If your audio signal is already on a USB bus, a laptop is the correct tool for the job. Outside of that, I assume the main reason to use the M2D2 is for its preamps, so if you want to use the analogue or AES outputs on the M2D2, any of the usual recorders should work just fine, Zoom, Mixpre, or a top-tier production recorder. I guess I'm really not clear why you want a special recorder just for the M2D2. If you just want the Sonosax pre-amps, plug it into whatever recorder you have. If you want to use the USB output, plug it into a laptop or phone. And if you want a recorder with pre-amps, get a decent recorder and don't use the M2D2 at all. If you really want Sonosax pre-amps with an integrated recorder ... sell the M2D2 and buy an SX-R4+. Quote Link to comment Share on other sites More sharing options...
EinF Posted Friday at 03:38 AM Report Share Posted Friday at 03:38 AM Hey @The Documentary Sound Guy, a reasonable query. My query in this case is in relation to the M2D2's place in the workflow of a radio journalist, where its proves handy on reporting trips, first in field and later in the edit and tracking. While certainly a question of technique and approach, in the field a devices small profile can assist in easing the casual nature of the moment as the source/interviewee speaks with the reporter, it's small size being a unique advantage over mixer/recorders like the Nagra 7/Mixpre/ etc. Though like both those units, when returning after a day in the field, the M2D2 has the benefit of doubling as the audio interface during the edit, tracking, and playback. As for what a field reporter might couple the M2D2 with. While using your phone in the field make sense in theory (Sonosax pitched this for journalists), there are times you are recording both ends of a sudden phone call (using both of the M2D2's inputs, recording into....?) or when you need your phone handy for incoming messages (say during a satellite two-way). That said, totally, a spare phone just for the M2D2 is an option, though seems like there'd be a simpler option? Which brings me back to Lectro's SPDR, which seems most fitting in this context (albeit pricier than a spare phone). Which is why I wondered wonder if there were any comparable alternative low profile recorders to pair with the M2D2 that maybe centered around USB or AES (such as TE's TP-7, although designed for a very different audience). But hey maybe an extra phone is the convenient option. Good to have a spare. Quote Link to comment Share on other sites More sharing options...
The Documentary Sound Guy Posted Friday at 06:23 AM Report Share Posted Friday at 06:23 AM I quite like the Roland hand-held recorders for that style of thing. R-07 is the current iteration. You'd be going analogue in, but it accepts line level on 1/8", and it would be fine for radio if it's just interviews. Kind of a mismatch in build and audio quality, but maybe it's what you are looking for? It doesn't quite duplicate; it has build-in mics, and a 1/8" mic jack, but the Sonosax would add XLR inputs and much better pre-amps. There's quite a number of journalist or amateur musician-focussed handheld recorders to choose from. Zoom H2, Tascam has one, Sony has one ... again, none of these are remotely in the same quality tier as Sonosax, but maybe they'd suit your size requirements? I would think most would be more convenient as full replacements though. Quote Link to comment Share on other sites More sharing options...
Fred Salles Posted yesterday at 07:28 AM Report Share Posted yesterday at 07:28 AM Hi. If you do need a portable recorder instead of a dedicated phone then I would strongly recommend to choose one with digital inputs. Analog inputs in consumer /low budget type of machines would significantly lower down the quality of the sound acquired by the M2D2, defeating its purpose. Especially the A/D converters. It seems they are still quite a rare find in the consumer type market. Few years ago only Sony and Marantz had digital inputs available. I guess you need to dig quite extensively to see what is available nowadays. Quote Link to comment Share on other sites More sharing options...
The Immoral Mr Teas Posted 21 hours ago Report Share Posted 21 hours ago 6 hours ago, Fred Salles said: Few years ago only Sony and Marantz had digital inputs available. I guess you need to dig quite extensively to see what is available nowadays. Also from old(ish) days, the microtrack (both models) had spdif digi in, which could be a great feature along with its size and cost. AES would have been better of course, but I don't know of any mini consumer recorder with AES in/out (and precious few non-mini ones). For me it was a great shame neither the F4/8 nor SD MP3/6 had AES I/O. J Quote Link to comment Share on other sites More sharing options...
