gsmyth Report post #1 Posted September 9, 2018 I started noticing a little too much noise out of my MP-1, and then, when I got it home and started inspecting it, noticed it was picking up me knocking on the case. Opened it up and started tapping on components, and the transformer is the culprit. Has anyone tried swapping out a new one? Worth it? Any good sources for the new part? Share this post Link to post Share on other sites
Glen Deakin Report post #2 Posted September 9, 2018 Have you tried sound devices? Share this post Link to post Share on other sites
RCarew Report post #3 Posted September 9, 2018 Which transformer? Assuming it's the input and you want to replace it you'd be paying a $100 for a new one from Lundahl, and it could be just a loose pin. I'd send it to SD for a service. Share this post Link to post Share on other sites
Glen Deakin Report post #4 Posted September 9, 2018 Not to mention when you get it back it will be good as new. Share this post Link to post Share on other sites
Dalton Patterson Report post #5 Posted September 9, 2018 Add up the time to source replacement parts, 1Hr+ Add time for analyzation and troubleshooting, 1.5Hr+ Add time for actual bench time with a hot iron, .5Hr+ Add time for assembly/disassembly and a thorough cleaning, 1Hr+ Thats 4+ Hrs @$50 is $200. Assuming your capable and experienced as the SD tech's. If you have the time and patience but not the cash, then go for it. However, resale wise I would run away from a device I found out was DIY'ed. I recommend sending it back to SD for a full tear down. Right now your resale value is nil. If you refurbish, it will sell for more $. Kudos to @gsmyth for opening up the hood tho 🆒💯🆗 and adding a pic!📸 Share this post Link to post Share on other sites
tourtelot Report post #6 Posted September 9, 2018 As well, you would be hard pressed to find a better transformer than the Lundahl. My guess is that it is broken/cold solder joint/loose. I might flip the board over and touch a hot iron to all the transformer pads and re-flow the solder. If it's a cold joint, that would fix it. Easy-peesy and probably worth the time since you have it open. Oh, and it's rare (but not impossible) for a transformer to go "bad". D. Share this post Link to post Share on other sites
gsmyth Report post #7 Posted September 10, 2018 7 hours ago, tourtelot said: As well, you would be hard pressed to find a better transformer than the Lundahl. My guess is that it is broken/cold solder joint/loose. I might flip the board over and touch a hot iron to all the transformer pads and re-flow the solder. If it's a cold joint, that would fix it. Easy-peesy and probably worth the time since you have it open. Oh, and it's rare (but not impossible) for a transformer to go "bad". D. That's what I thought! I'll definitely try giving it a once over with the iron. Thanks! 7 hours ago, Dalton Patterson said: Add up the time to source replacement parts, 1Hr+ Add time for analyzation and troubleshooting, 1.5Hr+ Add time for actual bench time with a hot iron, .5Hr+ Add time for assembly/disassembly and a thorough cleaning, 1Hr+ Thats 4+ Hrs @$50 is $200. Assuming your capable and experienced as the SD tech's. If you have the time and patience but not the cash, then go for it. However, resale wise I would run away from a device I found out was DIY'ed. I recommend sending it back to SD for a full tear down. Right now your resale value is nil. If you refurbish, it will sell for more $. Kudos to @gsmyth for opening up the hood tho 🆒💯🆗 and adding a pic!📸 I'm usually time and patience rich and cash poor, but you're totally right about resale and just my general "will this suddenly break on a gig" peace of mind. I sent SD an email, so I'll see what they say... Share this post Link to post Share on other sites
mikewest Report post #8 Posted September 10, 2018 Open the bottom of the case to expose the solder side of the board Whilst listening on headphones tap solder joints with plastic handle or similar Just try it!! mike Share this post Link to post Share on other sites
jon_tatooles Report post #9 Posted September 10, 2018 Based on that serial number that MP-1 will have its 18th birthday on September 27. It's still a teenager. Share this post Link to post Share on other sites
gsmyth Report post #10 Posted September 11, 2018 On 9/9/2018 at 11:20 PM, mikewest said: Open the bottom of the case to expose the solder side of the board Whilst listening on headphones tap solder joints with plastic handle or similar Just try it!! mike Tried this, it's really just the side of the transformer that makes any noise when I tap on it, but also, I think I might just be over sensitive. I did an A/B comparison to my audio interface pre and the noise floor was similar to my mp-1. I think I've just been cranking it way too high on quieter sets and back in the studio. 22 hours ago, jon_tatooles said: Based on that serial number that MP-1 will have its 18th birthday on September 27. It's still a teenager. Now that I did a more (or less) scientific test of it, I'm fine knowing that self-noise isn't an issue, but... I'm still a little concerned that I can hear myself tapping on the side of the transformer when the gain is up in the 7-8 range. Maybe the solution is "don't tap on the transformer?" haha Share this post Link to post Share on other sites
