gooninator484 Report post #1 Posted September 12, 2018 Using my 688 today on set the mixer cut off the monitor audio and the display froze simultaneously. The mixer could not be powered down. I had do a hard shutdown to get it to turn off. (Power off/held down menu button) That allowed it to power off but now will will not start beyond the splash screen. I’ve removed everything that can plug in. Including the aa’s and the memory cards. Still no luck. I’m using approved Sandisk SD and CF cards. I was only using three channels. 2 x SRC’s and a boom. I’m on firmware version v4.51. I’m dead in the water here. Anybody have any ideas? Thanks in advance Share this post Link to post Share on other sites
afewmoreyears Report post #2 Posted September 12, 2018 When you pull the int. batteries...? wait a couple minutes... re load batts, plug back whatever else powers the unit and restart.. It works for me on that rare freeze on startup, I have never had the unit freeze during use. Maybe reload a new firmware if nothing else works. That will get you back to square one. Save your set up of course.. Share this post Link to post Share on other sites
Philip Perkins Report post #3 Posted September 12, 2018 +1 on chill time before restart. A few minutes. If no go after that time to go to your back up and call SD. Share this post Link to post Share on other sites
Csaba Major Report post #4 Posted September 12, 2018 I puted back the previous version of firmware. Becouse of the same problem. Share this post Link to post Share on other sites
gooninator484 Report post #5 Posted September 12, 2018 Thanks for the feedback everyone. Is it possible to roll back the firmware if the mixer wont boot up properly? I’ve always managed firmware updates via the cf/sd card via the menu. But if I can’t get to the menu I can’t update firmware right? Share this post Link to post Share on other sites
gooninator484 Report post #6 Posted September 12, 2018 Update: After switching to a backup and leaving the 688 off over night it restarted normally this morning. Do you guys have any input on what the last stable firmware version was for a 688 so I can roll it back? Share this post Link to post Share on other sites
Johnny Karlsson Report post #7 Posted September 14, 2018 I would never recommend “rolling back” firmware. If anything newer firmware will have squashed bugs from earlier versions. I would rather try re-applying the latest one. Also, even if the cards are on the approved list, they could still possibly have issues. Crap happens. Personally, I reformat all cards before every work day (after backing up, of course). Maybe try with one of the cards in the recorder at a time to eliminate which one (if any) has a problem.... Best advice of all would be to contact Sound Devices directly and talk to one of their tech support people. They are great. Share this post Link to post Share on other sites
