EricCC Posted April 2, 2020 Report Share Posted April 2, 2020 On 3/27/2020 at 10:00 AM, Henchman said: Why? I have no problem with them from a drama perspective. This is the Stephen King short I just finished. Using the Deity Connect system. As well as my Vlog I just started shooting in my garage. I think the Deity is an amazing product. Especially for low/no budget filmmakers. I'll be shooting a feature once this virus blows over, using the Deity connects. Password for the short is "Festival" https://vimeo.com/376447791/721561e7be https://vimeo.com/400510224 In your short that sound at :23-25 seconds, is that from the wifi interference? on line "have you canvised all these houses?" there was a few more. it seems like a useless things to use. Deity should make a lav with a built in recorder and timecode (maybe thats not patented in USA) to work with there deity connect. if its small enough they could sell tons. Quote Link to comment Share on other sites More sharing options...
Henchman Posted January 2, 2021 Report Share Posted January 2, 2021 On 4/2/2020 at 5:28 AM, EricCC said: In your short that sound at :23-25 seconds, is that from the wifi interference? on line "have you canvised all these houses?" there was a few more. Nope, that was cloth noise. BTW, I mix dialog for a living, and there's nothing wrong with the system whatsoever. I have gotten absolutely terrible dialog to mix, that was recorded using top of the line equipment Quote Link to comment Share on other sites More sharing options...
Trey LaCroix Posted January 3, 2021 Report Share Posted January 3, 2021 5 hours ago, Henchman said: Nope, that was cloth noise. BTW, I mix dialog for a living, and there's nothing wrong with the system whatsoever. I have gotten absolutely terrible dialog to mix, that was recorded using top of the line equipment The Deitys sound remarkably good for the price point. If range and WiFi band saturation weren’t such an issue I’d feel fine using them alongside my Lectros. Quote Link to comment Share on other sites More sharing options...
Henchman Posted January 3, 2021 Report Share Posted January 3, 2021 3 hours ago, Trey LaCroix said: The Deitys sound remarkably good for the price point. If range and WiFi band saturation weren’t such an issue I’d feel fine using them alongside my Lectros. Exactly. I think they're an incredible option for indie filmmakers. Quote Link to comment Share on other sites More sharing options...
kavenzmann Posted September 28, 2021 Report Share Posted September 28, 2021 Hi, when I checked my Connect system today, suddenly the display of one of the TX units shut off without any reason. I can't get it on again. Is there any setting to activate the display again or is it a hardware failure? Quote Link to comment Share on other sites More sharing options...
kavenzmann Posted September 30, 2021 Report Share Posted September 30, 2021 It seems to be broken. I contacted the Deity support and they wil send a replacement. Another issue: When I use the Connect System in my soundbag (ORCA OR-280) with the MixPre 6 II, the RX unit is very close to the mixer and produces some kind of noise in my headphones (Sennheiser HD25). It doesn't matter where I put the cable, it's always there. It's also independent from any gain setting. When I touch the antennas it's getting a little better, but it's always there. I even stopped the 1st take yesterday, as I did not know, if it's also in the recorded file. It's definitely not, but it's still an annoying issue. When I shut of the DUO RX, the noise is gone immediately. Any ideas, how I can get around that? Quote Link to comment Share on other sites More sharing options...
Shastapete Posted October 1, 2021 Report Share Posted October 1, 2021 Sounds like 2.4ghz getting into the headphone cable/amplifier circuit. It used to happen with Zaxnet and my F8 – never had a problem since getting the Nova. On 9/30/2021 at 8:32 AM, kavenzmann said: Any ideas, how I can get around that? Move them further apart, add some sort of RF shielding between them, isolate your power connections (could be coming in through the shared ground), or upgrade your wireless Quote Link to comment Share on other sites More sharing options...
kavenzmann Posted October 1, 2021 Report Share Posted October 1, 2021 Thanks for the suggestions. The overall quality of the Deity Connect is really great, but there are still some caveats. Would have loved to pay double and get even better stuff. I only used the Connect once on a actual production and only for the interviewer on a doco. But I think I can trust the quality and realiability so far. Quote Link to comment Share on other sites More sharing options...
Sound Posted October 26, 2021 Report Share Posted October 26, 2021 I had corrupt files regularly in the internal recording of the deity connect deluxe kit. Send them to deity one month ago. No answer and no reaction to emails since then.. Quote Link to comment Share on other sites More sharing options...
daniel Posted October 26, 2021 Report Share Posted October 26, 2021 44 minutes ago, Sound said: I had corrupt files regularly in the internal recording of the deity connect deluxe kit. Send them to deity one month ago. No answer and no reaction to emails since then.. Sad to say Deity customer service is (in effect) non existent. Quote Link to comment Share on other sites More sharing options...
Sound Posted October 26, 2021 Report Share Posted October 26, 2021 I just received an answer, I guess some coworkers were on vacation. I hope everything will turn out well. Quote Link to comment Share on other sites More sharing options...
James Louis Posted October 28, 2021 Report Share Posted October 28, 2021 late to the convo here, but micro SD cards and micro SD card encasements, the card readers, can be the culprit. And this will be true wherever you stick that card and whatever you record onto it. Are the folks reporting corrupt files using verification software? The OS X finder is supposed to do a good job of this, but it won't catch unreadable errors or incompatibilities on a micro SD... Quote Link to comment Share on other sites More sharing options...
