Kisaha Posted September 16, 2018 Report Share Posted September 16, 2018 I have the classic Sennheiser mic mount and basket for the 416 but the o rings seem to be too sensitive. Plus, most of the times they have to order from Germany, which takes a lot of time to arrive (I have ordered 3 full sets since July and they told me end of this month or early October). Does any one knows if I can fit something like the K-Tek suspenders, or any Rycote Lyres, or a better quality type of o rings? Do I have to treat them with something to last longer (vaseline perhaps?). Cheers. Quote Link to comment Share on other sites More sharing options...
Glen Deakin Posted September 16, 2018 Report Share Posted September 16, 2018 You could always drill proper holes into your Sennheiser mount and make the lyers work. They are available in an upgrade. Just be careful that you drill the right size holes. Of course you'll have to get the positioning correct Quote Link to comment Share on other sites More sharing options...
Kisaha Posted September 16, 2018 Author Report Share Posted September 16, 2018 1 hour ago, Glen Deakin said: You could always drill proper holes into your Sennheiser mount and make the lyers work. They are available in an upgrade. Just be careful that you drill the right size holes. Of course you'll have to get the positioning correct Thanks I will do a little search about it, I would prefer a milder solution thought, that set cost me 900euros not that far away! Quote Link to comment Share on other sites More sharing options...
Glen Deakin Posted September 16, 2018 Report Share Posted September 16, 2018 Wowa that seems like a lot are you sure you're looking at the right item I believe you can just get the two lyers and not the conbox kit with lyers Quote Link to comment Share on other sites More sharing options...
Kisaha Posted September 16, 2018 Author Report Share Posted September 16, 2018 I meant the Sennheiser basket/fur cost me as much, and I am affraid to damage it! Quote Link to comment Share on other sites More sharing options...
Glen Deakin Posted September 16, 2018 Report Share Posted September 16, 2018 I've seen the upgrade done on older style rycote systems that are non modular so it can be done just find someone experienced and who knows what size hole needs to be made to accommodate the screw for each lyer. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted September 17, 2018 Report Share Posted September 17, 2018 Yes, the K-Tek Suspenders! I've used them in all manner of mounts and even stretched them over large diameter mic bodies. Since the Suspenders were released many years ago, I no longer use individual bands in any of my basket mounts. TIP: If the mic diameter is small enough that it slips a bit, simply add hardware store O-rings in front of and behind the Suspenders opening. Quote Link to comment Share on other sites More sharing options...
Kisaha Posted September 18, 2018 Author Report Share Posted September 18, 2018 11 hours ago, John Blankenship said: Yes, the K-Tek Suspenders! I've used them in all manner of mounts and even stretched them over large diameter mic bodies. Since the Suspenders were released many years ago, I no longer use individual bands in any of my basket mounts. TIP: If the mic diameter is small enough that it slips a bit, simply add hardware store O-rings in front of and behind the Suspenders opening. Do they fit the Sennheiser mount? Quote Link to comment Share on other sites More sharing options...
Glen Deakin Posted September 18, 2018 Report Share Posted September 18, 2018 I can't see how they would fit on the Sennheiser but if there's a way then give it a go Quote Link to comment Share on other sites More sharing options...
