Malfunction of repaired COS-11
Veit Norek
Hi Group,
we recently sent a COS-11 for repair to Kortwich. Since the mic was damaged right below the capsule,
their trick is to fix it with DPA cable. They said they had great results with that. Today we got it back
and obviously it is still broken. Can you maybe tell me from the attached sound file, what the problem might
be?
Thanks in advance
Veit
FEHLERT01_3.WAV
34 minutes ago, afewmoreyears said:
Dont know if he was replaced
He was. The reason why they are the only people who can work on them is because Sanken sent them a machine that can’t open the capsules and they are the only people that have one. So despite who is working there, the machine is what allows for the repair.
Too risky to use the repaired ones, I have mine repaired once, they replaced the old cable to a Shure mic cable. In general, it sounds fine... but later on, it goes on and on with lots of problems, little noise like the cable with he capsule, or even RF antennas etc.
best to get a new one or even a used one. Don’t repair it.
  • 4 months later...
On 9/18/2018 at 4:12 AM, JonG said:
Aside from Sanken, the only people that can repair a cos-11 are Wilcox Sound.
Yes that was right until 2017.
If you are located outside of U.S.A (in Europe for example) we can do this repairing for you.
We have customers from U.K, Canada, Singapore, Australia, Bulgaria etc. since 2017.
We have Facebook & Instagram pages where you can see many samples of capsule repairing and cable renewing.
https://www.facebook.com/cos11repair/
https://www.instagram.com/cos11_repair
or you can send e-mail to: c_alingan@msn.com
Cihan
A little advice to all cos11 users:
When you're buying a new cos11, pay little much and buy 3mt. cable length option. (it will be approx. 3.25mt)
Cut the cable to 2 equal pieces (1.62mt. each) before using it and resolder the connector.
You can keep second part cable for renewing in future (if you want to replace old sticky cable with original one)
Cheers
On 2/5/2019 at 3:54 AM, nagnila said:
Yes that was right until 2017. If you are located outside of U.S.A (in Europe for example) we can do this repairing for you.
We have a Facebook page where you can see some samples of capsule repairing and cable renewing: https://www.facebook.com/cos11repair/
or you can contact me directly from c_alingan@msn.com.
Cihan
Cheers
eline sağlık hocam burada böyle bişey bulacağımı tahmin etmezdim. :)
