MixPre 10T - Backup USB Card - Inspecting/Confirming File List Possible Within The MixPre?
Dave
Hi All,
Another MixPre 10T question : Can't seem to find the answer - when a USB backup-mirroring card is in the MixPre, is it possible to view the contents of this USB stick from the menu? There has been a couple times when I had the feeling that I should check the USB card to make sure that it was indeed functioning as expected and mirroring the main SD card. Do you have to check files from a computer only?  I'd be pleased if there was some way to confirm the file backup process manually by inspecting the contents of the USB backup card in the MixPre menu.
And another question I saw asked on the MixPre Facebook forum : with the upcoming ability to hook up an external fader panel (Korg nano Kontrol Studio, for example) to the MixPre, do you have to forfeit the USB backup card port?  Are there plans to engage the bluetooth capabilities of the Korg to the MixPre and still be able to use the USB port for a backup card as normal?
Thanks again.
Regards,
Dave
