James Bull Posted September 29, 2018 Report Posted September 29, 2018 On 9/27/2018 at 11:14 PM, Dalton Patterson said: With hot shoe compatibility it is a no brainer. I recently tried a uwp-d11 on the sony pxw-z90, with the smad-p3 hot shoe adapter. Unfortunately with this combination I could not find a way to defeat the camera’s AGC, and the result was also much noisier than using the xlr inputs on the handle. There is some evidence online of others having this same problem, so try before you buy! It it may also be different with other cameras, so YMMV. J Quote
edward chick Posted September 29, 2018 Report Posted September 29, 2018 Depending on available real estate (which is at a premium on cameras these days), I use either a Lectro SR5p or LR receiver. Network clients still rely heavily on camera mix so it’s sr5 series for them. Commercial clients usually just want a scratch for the edit so they get the LR with Ambient tiny Lock it bongoed together, works fine. The Wisycom ENG series is looking good I like the size of the receiver. Not sure about the Deity and 2.4ghz, I do like the fact that manufactures are starting to take our needs into consideration though. Quote
Dalton Patterson Posted September 29, 2018 Report Posted September 29, 2018 5 hours ago, James Bull said: the result was also much noisier than using the xlr inputs on the handle. I think that will be OK. I will test and listen to one first. I will look into the AGC issue. Thanks for the input @James Bull!!!! Quote
JonG Posted December 27, 2018 Author Report Posted December 27, 2018 To resurrect this thread, I’d like to take a pole on what your hop needs are. Please use the following format: Types of jobs you do: Camera audio will be final or reference: Mono/Stereo hop: Most common cameras you work with: TC needs: For me, I used to do a lot of broadcast/reality stuff and my stereo mix was used in the edit. Those jobs often used cameras like the HDX900, and it was common to use saddle bags with two 411s feeding the camera. Today those jobs are using Red, Alexa Mini, C300, FS7 cameras where real estate is sparse. But those jobs want a mono scratch track and TC these days. Same goes for narrative work, except that the Alexa is likely the camera of choice. Give me your thoughts and what your ideal setup would be. Quote
KRF Posted December 27, 2018 Report Posted December 27, 2018 Timely question. Drama shoot using two Alexas. They want timecode and scratch audio on both for the rushes. I'm using Ambient nanolockits, Ambient slate and Masterlockit on SD688 also for sound report. Audio is two Lectro IFBT4 (one boom, one lavs) to SRbs on cameras. Making special cable 2xTA3 to 5 pin XLR for the Alexas. Quote
Constantin Posted December 27, 2018 Report Posted December 27, 2018 Types of jobs you do: narrative Camera audio will be final or reference: scratch (if that) Mono/Stereo hop: mono Most common cameras you work with: Alexa TC needs: yes, always somehow on my jobs they never want scratch audio. If they did, I‘d use my Sennheiser IEM gear, with the same mix I‘m broadcasting around the set anyway. I have all the Lectro gear ready for a proper hop, but they don’t want it. Which is a shame really, because now that I‘ve got the gear, I really want to play with it... at most they‘d ask for something for instant playback, but that’s it Quote
JonG Posted December 27, 2018 Author Report Posted December 27, 2018 @Constantin that’s awesome. If my scratch track has wireless dropouts ppl freak out like it’s the end of the world on a lot of my jobs, narrative or otherwise. lol Quote
codyman Posted December 27, 2018 Report Posted December 27, 2018 I've got a sneaking suspicion that Lectrosonics is going to make a "bag hop stereo transmitter" using their "Duet" technology. I remember people asking if that was going to be the case considering they've only released the half rack transmitter and I think it was a patented Lectrosonics Tumbleweed™ response when inquired upon. Quote
JonG Posted December 28, 2018 Author Report Posted December 28, 2018 Types of jobs you do: Camera audio will be final or reference: Mono/Stereo hop: Most common cameras you work with: TC needs: Quote
Jack Norflus Posted December 29, 2018 Report Posted December 29, 2018 A majority of my work these days is on documentary and news magazines shows like 60 minutes. Primary audio is almost always taken from the camera (usually Sony F5, F55, Cannon C300, VariCam). For sit down interviews I'm always hardwired to the cameras (usually 3 to 4 cameras per interview). When we aren't tied down I'm using a Zaxcom hop. Which consists of the wideband camera link transmitter and several RX200 receivers - 1 per camera. The rx200 will output 2 channels of audio and time code on a single carrier. The rx200 is small lightweight and will run all day on a set of lithium AA batteries. I also always record a backup of the camera feed in the camera link. The backup recording is primarily used for transcription - I will use zaxconvert to convert the files to mp3 - but they can also be converted to BWAV files if needed. Quote
IronFilm Posted December 29, 2018 Report Posted December 29, 2018 On 9/28/2018 at 3:50 AM, hiro nakamura said: Sony UWP D11 for hops, and IFB monitoring as well. Two AA, 12 -15hours running time. Not even bother to turn them off in the middle of the shoot. If it’s Fs7 or even A7s, their Sony hotshoe could go cable-less on cameras. And I could swap them around for hops and listening. Which battery are you using with the UWPs? Quote
Derek H Posted December 30, 2018 Report Posted December 30, 2018 Hey Jack, for your news magazine stuff do they really request two channels of sound on EVERY camera? Seems like massive overkill and just plain laziness on their part. But if they’re paying for all those receivers that’s great. When I have a multi camera interview I typically run a snake to the primary camera and then just single XLRs to the others if possible/practical. Or a G3 on DSLRs or smaller secondary cameras if they’re mix and matching. Usually they don’t have specific requests. Quote
edward chick Posted December 30, 2018 Report Posted December 30, 2018 I think it comes down to redundancy for the networks. I’ve worked on Dateline, 20/20, Sunday Morning, etc, for almost 20 years. They have always requested all cameras in a multi cam interview get audio. It may be that their editors are working on multiple projects with immediate deadlines, and don’t have the time to sync audio with picture. They do request the .wav backups now. I have had a situation where we shot on a DSLR a few years ago for an nbc feature doc and the editor did use my .wav files. Quote
JonG Posted December 30, 2018 Author Report Posted December 30, 2018 All my work, narrative, doc, reality, commercial, etc. Want a mono mix to the primary camera at minimum, sometimes they want audio to all cameras, and TC on all cameras. I haven’t worked on a show that was going to actually use the camera audio in years, and haven’t been asked for a stereo mix of any kind in just as long. It seems like most ENG type work I do is being shot on “cinema” cameras, and I’m guessing that post has begun to figure out that re syncing audio isn’t as time consuming as they assumed it was. Quote
Philip Perkins Posted December 30, 2018 Report Posted December 30, 2018 Non-broadcast, for web etc mostly here. Double system+TC (if the cam will take it)+ mono ref feed, nearly always wireless. Many shoots are now maybe 1 "real" camera (Arri etc) with all of the above, and one or a few more of the Sony A7s type with ref track only. A TC slate often, but not always. No one wants to bother to try to set the A7s code to something close to master TC. Multitrack pre-fade iso audio expected, esp if more than 2 channels are in play. The only time "hero audio from camera tracks" enters the discussion is when time from shoot to presentation is very short, and even then most DITs are so fast with TC autosync that they go that way anyhow (esp if I have a lot of wild tracks, or I'm rolling through while camera stops or reloads etc.). This seems to be the pref for complex jobs with lots of crews, since the DIT is setting up their footage database. Having them gather, check, note and account for all assets as we go seems like a good idea. Quote
Jack Norflus Posted December 31, 2018 Report Posted December 31, 2018 22 hours ago, Derek H said: Hey Jack, for your news magazine stuff do they really request two channels of sound on EVERY camera? Seems like massive overkill and just plain laziness on their part. But if they’re paying for all those receivers that’s great. Yes. Yes. And yes! Quote
daniel Posted January 7, 2019 Report Posted January 7, 2019 ypes of jobs you do: corporate/scripted/broadcast Camera audio will be final or reference: reference mostly, final sometimes Mono/Stereo hop: mono. Most common cameras you work with: Ursa/Alexa/Eos/Sony TC needs: preferable but not often specified. Crazy fantasist probably, but I've been thinking the TC board of a tentacle/moze/TCB UB could fit inside a AA battery eliminator and still leave room for a 3.7 li-on battery to power both RX and TC - use smart phone to set parameters and lots and lots of G3 (and similar) RX can get repurposed. If the client doesn't want audio the device should work as a stand alone with a cold shoe accessory etc. Quote
Eric Posted January 14, 2019 Report Posted January 14, 2019 I use a Sennheiser G3 for a mono scratch track. Sync box on camera. Some clients like the slate as well. Slate mandatory without TC input. If they want master audio to camera a Lectrosonics D4 for a hop. Plus a sync box (and record just in case). Plug in for interviews. Usual cameras: Cannon c-300 red Sony fs7 Sony F55 Quote
Toddsound Posted January 17, 2019 Report Posted January 17, 2019 Types of jobs you do:Mostly Multi-camera interview/ Documentary/ Sports Features/ News Magazine/ Some Network News Camera audio will be final or reference: Camera just reference. I use LR on camera Mono/Stereo hop: Mono 95% of the time Most common cameras you work with: Amira/ Alexa Mini/ Sony F55/ C-300 TC needs: Use Betso TCX-2 on every camera Quote
KGraham045 Posted January 17, 2019 Report Posted January 17, 2019 I have a CL3 and 3 RX200s. And I have 2 modded ERX2TCDs I generally just use as lockits. Everything I work on is generally TC synced and if they pay for it I’ll provide a full UHF Stereo Hop. But in general I always provide at least a mono scratch feed and/or TC. And then provide Wavs for post to sync if wanted/needed. Quote
Rifthead Posted January 23, 2019 Report Posted January 23, 2019 Types of jobs you do: Documentary and Corporate Camera audio will be final or reference: almost always reference Mono/Stereo hop: Mono Sennheiser G3 RX and/or G3 IEM Most common cameras you work with: Sony FS7, Panasonic EVA1, Canon C300 TC needs: sync boxes if run and gun I use the Sennheiser IEMs as my IFBs as well as hops, which is great because I've only got one transmitter in the bag for both. Curious if others here offer cabled TC if a client doesn't want to pay for sync boxes, if cameras will be locked off. Quote
JonG Posted January 24, 2019 Author Report Posted January 24, 2019 @Rifthead the G3/IEM setup certainly is clever. Regarding hard wired TC, I’d guess that most here would do a courtesy jam if client doesn’t want to pay for a lockit but I highly doubt anyone would be willing to lay down cable for a cheapskate client. I could be wrong. Opinions? Quote
chrismedr Posted January 24, 2019 Report Posted January 24, 2019 3 hours ago, JonG said: @Rifthead the G3/IEM setup certainly is clever. Regarding hard wired TC, I’d guess that most here would do a courtesy jam if client doesn’t want to pay for a lockit but I highly doubt anyone would be willing to lay down cable for a cheapskate client. I could be wrong. Opinions? agreed. having a bunch or long TC cables made (that people step on and trip over) does sound both, more expensive and inconvenient then buying one of the low cost TC boxes (which most people have already anyway). besides if we take the equipment cost /100 per day rental, a tentacle would come in at 2.50, or lets say 4.00 - if that's too expensive for a client on a dual system job then you probably have bigger problems. Quote
Vincent R. Posted January 24, 2019 Report Posted January 24, 2019 20 minutes ago, Frido Beck said: The service and extra work and extra risk What service and extra work? You jam it and slap it on. done till, lets say, a re-jam at lunch. Extra risk? If they brake it they pay for damage. IMO, purchase price is always a starting point for rental price, as is with every industry out there, I do rent a Mercedes for much more than a Kia, or lets say a scooter. But that is a discussion we had a million times here on the forum.... Quote
Vincent R. Posted January 24, 2019 Report Posted January 24, 2019 Just now, Frido Beck said: Everyone their own business practice but I'm not renting my UltraSync ONE's for €4 a day. If they can pay for more camera's they can pay for more timecode on camera's and possible wireless reference tracks. Sure, 4$ is low, make it a 10-er or something with all the cables, and good for you if you can get 50$ obviously. I was merely referring to the purchase/rental ratio (whatever that may be in the region) as mentioned before. The camera department gets a mattebox for a couple of $$, which is the same kinda percentage deal of a purchase price. Quote
