newzhack Posted October 15, 2018 Report Share Posted October 15, 2018 If you set the time code on the 664 to 24h run it will start off with the time of day each time you start it. I guess it is setting itself to the internal time of day. Will that timecode be frame accurate since it is using the system info instead of the time code circuitry. Quote Link to comment Share on other sites More sharing options...
Dalton Patterson Posted October 15, 2018 Report Share Posted October 15, 2018 Yes Quote Link to comment Share on other sites More sharing options...
newzhack Posted October 16, 2018 Author Report Share Posted October 16, 2018 thanks Quote Link to comment Share on other sites More sharing options...
Mungo Posted October 16, 2018 Report Share Posted October 16, 2018 But will it still be accurate when you start the machine again after a power off, within that period of time the blue TC has been flashing? Quote Link to comment Share on other sites More sharing options...
Dalton Patterson Posted October 16, 2018 Report Share Posted October 16, 2018 1 hour ago, Mungo said: But will it still be accurate when you start the machine again after a power off, within that period of time the blue TC has been flashing? Yes. Sample/Timecode Accuracy ± 0.2 ppm (0.5 frames per 24 hours) Timecode and Sync Modes Supported: off, Rec Run, Free Run, 24h Run, External Frame Rates: 23.976, 24, 25, 29.97DF, 29.97ND, 30DF, 30ND Accuracy: Ambient generator, 0.5 frame in 24 hr Yes, we can jam to the internal clock.This mode is called 24Hr Run. You can either leave the 664 in 24Hr Run or change the TC mode back to Free Run.The generator will hold good code for 2 hours. After that it will shut down and you will get all 00s on power up if you are in Free Run. Quote Link to comment Share on other sites More sharing options...
Mungo Posted October 18, 2018 Report Share Posted October 18, 2018 On 10/16/2018 at 4:31 PM, Dalton Patterson said: Yes, we can jam to the internal clock. This mode is called 24Hr Run. You can either leave the 664 in 24Hr Run or change the TC mode back to Free Run.The generator will hold good code for 2 hours. After that it will shut down and you will get all 00s on power up if you are in Free Run. Thank you. 24Hr Run always selected has been working great for me. Very convenient solution. Quote Link to comment Share on other sites More sharing options...
