Lancashire soundie
4 channels audio over radio camera on OB
I need an answer for a question which may come up soon.  Possibly up to 4 presenters on handheld stick mics, feeding 2 radio receivers on the back of an RF camera on an OB.  Is it possible to feed those 4 channels into the camera (no, I don't know the camera model yet) and have them fed over the digilink via SDI, to the truck, so the audio mixer can control the levels independently?
Or I give the audio assistant following the RF cameraman a simple mixer and 4 channels of radio, and have him mix them and give the camera a mono feed.
Share this post
Link to post
Out of curiosity, "up to 4 presenters on handheld stick mics, feeding 2 radio receivers" - 2 x dual channel RX into a 4 channel camera or something else?
Share this post
Link to post
Brilliant, thanks guys.  I'll bookmark that little box in case it comes up.  I'm just hedging bets at the moment, trying to get production interested in having 4 radio sticks instead of 2 [ugly] wired mics shared between 3-4 people.
Share this post
Link to post
Thanks for this interesting thread. questions: if the link from camera to the truck is wireless, how would you go about inserting the 4 audio tracks into the Black Magic box? you would still need either a wireless AES link (times two for 4 tracks), or 4 analog feeds into the box. Maybe you'll get lucky and the camera will have the appropriate inputs on board. The Black Magic box would work, but might get a bit clunky in practice as it will require 12v DC and uses 1/4" TRS inputs to complicate things. Because the box is post video processing coming out of the camera,there would be no delay/offset for sync. Direct input to camera, bypassing the box would obviously be a simpler workflow.
Share this post
Link to post
If it’s a camera with AES inputs (Sony F5/F55, Arri Amira, etc) you can feed it 4 channels. Sticking 2 SRc units on there would be unwieldy, but would work with their AES backplates. I’ve fed 4 channels into an F5 several times, hard lined via a 633 with no issues. And SDI can carry up to 8 audio channels, for what it’s worth.
Share this post
Link to post
I’d say keep it simple.  Feed the camera good sound whether that’s a good mix on one or two tracks or four discrete iso tracks and it will travel along with the picture however they send it.
Share this post
Link to post
Lectrosonics D4 can send 4 channels of audio. RX can output analog or AES.
I have been using this as a camera hop for a number of years (when not using a G3 scratch track). Likely some are familiar with it and some are not.
It has it's pros and cons (which I won't get into), but can be helpful in the odd 4 channel send situation.
https://www.lectrosonics.com/US/Digital-Wireless-System/category.html
Share this post
Link to post
I've also done this half a dozen times. Sony PDW-F800, F55, Amira. Using SD633, 552, 788T, 688 units.
HD-SDI carries 16 channels of AES.
The most I've seen available is 8 channels using a VCR such as a Sony  PMW-1000 XDCAM SxS Memory Recording Deck but that is really just displaying 8 channels on playback. For AES digital in it is usually just 4 channels on camera, VDRs, if you use an audio embedder it will take up to 16 but you may require 2 embedder units to add audio to 16 channels since each one can only add 8 channels. Some really expensive units allow access to 16 channels of AES input on 8 BNCs such as AJA FS-1 frame synchonizer.
Share this post
Link to post
