Allen Rowand
USB power a Sound Devices 302?
I'm thinking about picking up a 302 as a utility mixer. The external power will work on 5v, would it be feasible to build a USB to Hirose cable to power it? Could be a good way to power it until I step up to a BDS, as well as an option for use out of the bag. Thanks!
1 hour ago, Derek H said:
It will run a looong time on lithium AAs...
I’m not a fan of fiddly USB power cables.
Any brand recommendations? I've heard stories of how batteries like to get stuck in the tube.
There are more than a few reports of rechargeable AAs getting stuck in the tube. I use regular alkalines, (which last quite a while) when external pwr. is not an option. I have not tried making a USB to Hirose adapter cable, which may work, but that's at the bottom of the 302's 5-18 volt range.
That's a good point about the voltage, Rick. Maybe I'd be better off with something like a Sony NP sled- I have a bunch of batteries for the MP6 and my camera, and the 7.2v gives me a little more leeway.
seems like a better idea to me. even the smallest form factor (2000mAh) should give you a very long run time.
for what it's worth, I'm using using white eneloops (sanyo generation) in my 302 and never had any problems
