Allen Rowand Posted October 26, 2018 Report Share Posted October 26, 2018 I'm thinking about picking up a 302 as a utility mixer. The external power will work on 5v, would it be feasible to build a USB to Hirose cable to power it? Could be a good way to power it until I step up to a BDS, as well as an option for use out of the bag. Thanks! Quote Link to comment Share on other sites More sharing options...
Derek H Posted October 26, 2018 Report Share Posted October 26, 2018 It will run a looong time on lithium AAs... I’m not a fan of fiddly USB power cables. Quote Link to comment Share on other sites More sharing options...
Allen Rowand Posted October 26, 2018 Author Report Share Posted October 26, 2018 1 hour ago, Derek H said: It will run a looong time on lithium AAs... I’m not a fan of fiddly USB power cables. Any brand recommendations? I've heard stories of how batteries like to get stuck in the tube. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted October 26, 2018 Report Share Posted October 26, 2018 I do ok on Energizers. You can use an ext DC supply you wire yourself--SD sells the Hirose DC connectors. Quote Link to comment Share on other sites More sharing options...
Rick Reineke Posted October 26, 2018 Report Share Posted October 26, 2018 There are more than a few reports of rechargeable AAs getting stuck in the tube. I use regular alkalines, (which last quite a while) when external pwr. is not an option. I have not tried making a USB to Hirose adapter cable, which may work, but that's at the bottom of the 302's 5-18 volt range. Quote Link to comment Share on other sites More sharing options...
Allen Rowand Posted October 27, 2018 Author Report Share Posted October 27, 2018 1 hour ago, Rick Reineke said: I have not tried making a USB to Hirose adapter cable, which may work, but that's at the bottom of the 302's 5-18 volt range. That's a good point about the voltage, Rick. Maybe I'd be better off with something like a Sony NP sled- I have a bunch of batteries for the MP6 and my camera, and the 7.2v gives me a little more leeway. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted October 27, 2018 Report Share Posted October 27, 2018 Rechargables tend to be a bit larger than Energizer Ultimate Lithiums. Quote Link to comment Share on other sites More sharing options...
chrismedr Posted October 27, 2018 Report Share Posted October 27, 2018 10 hours ago, Allen Rowand said: That's a good point about the voltage, Rick. Maybe I'd be better off with something like a Sony NP sled- I have a bunch of batteries for the MP6 and my camera, and the 7.2v gives me a little more leeway. seems like a better idea to me. even the smallest form factor (2000mAh) should give you a very long run time. for what it's worth, I'm using using white eneloops (sanyo generation) in my 302 and never had any problems Quote Link to comment Share on other sites More sharing options...
