Analogue output of Zaxcom RX200
Soundio
Hey fellas, I discovered the phenomenon is,first of all,I use SD633, Zaxcom RX200 and Trx743stereo, when I switched the SD633 and RX200 from digital to analogue, then two channels(CH1&CH2) output became one channel output(only CH1), and cable is fine,anybody know what going on?
1 hour ago, John Blankenship said:
Standard AES uses a single balanced output for stereo, but analog needs two.
So, on the RX200, stereo AES out uses TA5 pins 1-2-3, whereas analog stereo out uses pins 1-2-3-4-5. See the manual for the wiring.
Thanks for your response, I have plug in two XLR connectors, TA5F to XLR CH1/XLR CH2. when I switch on tone at RX200, RX200 display two signal channels, SD633 only CH1 has signal, CH2 is super super low level, and noise.
