Analogue output of Zaxcom RX200
Soundio Li
1 hour ago, John Blankenship said:
Standard AES uses a single balanced output for stereo, but analog needs two.
So, on the RX200, stereo AES out uses TA5 pins 1-2-3, whereas analog stereo out uses pins 1-2-3-4-5. See the manual for the wiring.
Thanks for your response, I have plug in two XLR connectors, TA5F to XLR CH1/XLR CH2. when I switch on tone at RX200, RX200 display two signal channels, SD633 only CH1 has signal, CH2 is super super low level, and noise.
