saadasound Posted December 17, 2018 Report Share Posted December 17, 2018 I just got my SRC B1 and a SMWB B1, and trying to smart tune seems to always tune to a "mismatched" frequency outside the range of the transmitter. I also tuned on B1N and still tunes to mismatched frequency. Anyone have this same issue or know if I'm missing something? Also, It feels like the SMWB runs pretty low with COS11's... Had to have my gain on them set close to 35 to get movement on the SRC. THANKS! Steve Quote Link to comment Share on other sites More sharing options...
Johnny Karlsson Posted December 17, 2018 Report Share Posted December 17, 2018 Could it be the frequencies in block 23 that are “not there”? I had that happen when I first got the B1 SRC - it scans and finds frequencies in that range, but the transmitter can’t go there. Quote Link to comment Share on other sites More sharing options...
saadasound Posted December 17, 2018 Author Report Share Posted December 17, 2018 Correct, that’s exactly what it’s doing. Did you figure it out in the end? Quote Link to comment Share on other sites More sharing options...
Johnny Karlsson Posted December 17, 2018 Report Share Posted December 17, 2018 Well, kind of depends what you mean by figured it out... There are a set of frequencies within block 23 (and thus also in the upper end of B1) that are not available for use in the US. This basically means don't tune the receiver to these specific frequencies if you want to be able to use your transmitters with it. I have attached the Block 23 frequency table from Lectro's website below. It shows these as TV Channel 37 in yellow and "not available in the US". I'm not sure why these freqs are available on the receivers, but it's only illegal to transmit on them, so maybe it's easier to just leave them in for manufacturing. Perhaps someone from Lectro can chime in....? Quote Link to comment Share on other sites More sharing options...
Gordonmoore1 Posted December 18, 2018 Report Share Posted December 18, 2018 On Page 24 of the manual, "Finding Clear Frequencies with Smart Tune", there is a note about scanning B1 or Block 23. From the Setup menu select Smartune. Next select which receiver you wish to tune (UP or Down arrow to select 1 or 2 - then press Menu/Select). Then select which block you wish to scan using the up/down arrows - select either B1N or 23N for correct scanning (N for North America). These will then skip over the 608-614 frequencies reserved in North America for Astronomical frequencies. This will help you avoid getting a freq your US/Canada transmitter cannot use. The SRC can be used internationally since it is a receiver and not subject to the emissions rules by which transmitters are governed. Quote Link to comment Share on other sites More sharing options...
al mcguire Posted December 19, 2018 Report Share Posted December 19, 2018 I think there is supposed to be another "F" in the acronym Quote Link to comment Share on other sites More sharing options...
saadasound Posted December 19, 2018 Author Report Share Posted December 19, 2018 Read the manual first thing, still chooses a mismatched frequency. Quote Link to comment Share on other sites More sharing options...
karlw Posted December 19, 2018 Report Share Posted December 19, 2018 What firmware versions are in your SRc and SMWB? What happens if you select Block 21 or 22 only (i.e. not allow it to choose from the entire B1 band) with SmartTune? If you manually tune receiver to a known good (US legal) frequency, and use IR sync to set the transmitter, what happens? Quote Link to comment Share on other sites More sharing options...
