nonisound Posted December 27, 2018 Report Share Posted December 27, 2018 Hi I have a question about your choice of antennas. Mostly I'm working from my trolly, and a lot of times I am a bit far from the set. I'm very happy with Betso CPAA-18. Having an active antenna that compensates for the long cable distance is a great option. As they are a bit heavy , I'd like to have an option for portable bag work. Also they will be my back up for CPAA-18 in a case of ... I am thinking about RF Venue Diverisi Fin. Of course first difference is they are Passive antennas, but it would be great to hear more from people who use them. Please share your option for cart or bag work. Thanks a lot Noni Quote Link to comment Share on other sites More sharing options...
JonG Posted December 27, 2018 Report Share Posted December 27, 2018 For cart work I use the good old passive PSC shark fin with a Shure “pipe bomb” passive dipole. I typically remote them to either side of set, and that gets me great coverage. I typically use 100’ cables. You only need active antennae if your cable run is longer than that. For bag work I just use the whip antennae of my receivers. However, in the past when I needed to be working out of a bag but not booming anything, and still a considerable distance from talent, I’d put the PSC shark fin with either a Lectro SNA600 or the Shure pipe bomb on a stereo T bar up at the top of my boom pole connected to a PSC RF Multi SMA on my bag. That got me incredible range and allowed the talent to wander a little without getting dropouts. Quote Link to comment Share on other sites More sharing options...
Jim Rillie Posted December 28, 2018 Report Share Posted December 28, 2018 I use the RF Venue Diversity fin on my smaller cart. On the main unit cart i use 2 Lectro ALP620s. In the bag, I use whips. Range, of course is stellar with the Lectro fins, but the RF Venue is a close second Whips have much more limited range, so I keep the receivers as high as I can in the bag. Quote Link to comment Share on other sites More sharing options...
Christian Spaeth Posted December 29, 2018 Report Share Posted December 29, 2018 If you have some sort of distro for your bag or don't use too many receivers, mounting two dipoles (I made my own from SMA cables) on your harness or bag works well, for extreme range situations replace these (or one of them) with sharkfin (I use the Zaxcom Bluefins). Quote Link to comment Share on other sites More sharing options...
nonisound Posted December 31, 2018 Author Report Share Posted December 31, 2018 Thanks alot guys for your comments and suggestions. I am running Besto CPAA-18 from Lectro Venue 2. As Bestso are working only as an Active antenna, I am thinking to chuse BlueFin to have it as a buck up, or when I need to go from the bag. The price is really good, and they have a good amount of db gain. I would like to use the opertunity to ask if anybody have an experiance with RF Venue Spotlight antenna. Quote Link to comment Share on other sites More sharing options...
