RadoStefanov
Bubblebee DPA 406X concealer review
Bublebee industries new DPA 406X concealer is the best one I have tried to this day. Softer flexible material is so much better for sticking on the inside of Tshirts without an obvious fabric bends and on uneven surfaces. The tape is the usual best we expect from Bubblebee. The metal buffer helps a lot keeping noisy objects away and the metal clip “ the design of which came from the design of the DPA slim and concealer “ is very easy for a corporate work compared to a old school regular clip. You can also clip on the inside of shirts “ for VIP people who do not want tape on their expansive clothing. I don’t see a reason to use the original Dpa concealers any more.
Another top notch top quality release from Bubblebee Industries.
Thank You BB
51107859_10218487685923321_1460133394233950208_o.jpg51109426_10218487685283305_7508262437305450496_o.jpg51078342_10218488414381532_9052795417829310464_o.jpg51344553_10218488253737516_9049639840932429824_o.jpg51137465_10218488359380157_6989321123980640256_o.jpg51381281_10218488254017523_1923443512297127936_o.jpg51132453_10218487686163327_8584472772283990016_o.jpg
I'm assuming the wire clips can be removed if needed.
I found the wire loop on the Slim concealers to be the most microphonic part of that concealer. To be honest I'm not a fan of the DPA Slim's concealer.
Will have to give the new Bumblebees a try when my local dealer gets some in.
As always thanks for the write up.
You can see it is removed on one of the pictures. But on the Bubblebee it is soft rubber so it does attach silently and more secure.
I actually like it on for certain wardrobe.
