filmsalang Posted February 16, 2019 Report Posted February 16, 2019 I am a user of Zaxcom Nomand and Maxx... My Maxx is great and never gets problem.... but, Nomad....hmm.... Yesterday, I got record 10 iso tracks on Nomad with 1 line level and 5 mic level all for wireless, and returen 1/2, 3/4 through Maxx outs... I set the basic settings for mic and line level and other labels before shooting day. and the shooting day, I got screwed.. When power up, the level is so low.....cranked all the way up the gains but nothing happens..... Actually I got this problem several times.... and as usual with this problem..I turned off and on....again...and again... but this time it didn't do any magic...so I change my input 1 to mic level...(this was for my lectro LR receiver).. and....turned 2 or three times on and off. finally I got levels..... and I never turned off even lunch time....because I got scared this would happen again.... ...I'm not sure....If any nomad user has the same problem as me... I even clear the whole setting(default setting) before shooting day, but...It happened again. I need any help..!!! Thank you for reading. Quote
resonate Posted February 17, 2019 Report Posted February 17, 2019 You should contact support instead of venting here. They usually respond very fast. Maybe your analog board is acting out. They will know. You’ve written you got that many times. What exactly were you waiting for? Equipment does not fix itself... Quote
filmsalang Posted February 17, 2019 Author Report Posted February 17, 2019 5 hours ago, resonate said: You should contact support instead of venting here. They usually respond very fast. Maybe your analog board is acting out. They will know. You’ve written you got that many times. What exactly were you waiting for? Equipment does not fix itself... Yes,,,I will do soon... but looking for some fast way to fix it from field experience. My Nomad already have changed some input board for phantom power issue cause I bought this unit early time. If I live in the U.S., I would have contacted right away...but I live in S. Korea. Quote
resonate Posted February 19, 2019 Report Posted February 19, 2019 I see. Sorry for being harsh. But it seems like, it will have to go to some service... Quote
sonyslave Posted February 27, 2019 Report Posted February 27, 2019 I recall having a similar issue a few firmware versions back...maybe 3-4 years ago? I would have to toggle between mic and line for signal to "pass". It did not happen often and has not done this again in a long time. Quote
resonate Posted February 27, 2019 Report Posted February 27, 2019 Remember to reset to factory settings when changing firmware, as i know from experience that not doing that w/Nomad can cause all sorts of buggy behavior. Also, do not restore settings from Nomad memory presets or cards saved with earlier version of the firmware. Always rebuild your setup with new firmware. Quote
