Sign in to follow this
Stephenvit
Soundfield SPS200 problems
I posted this on another forum but didn't get any reply. I've read comments from some here who have used an SPS200. I'm wondering if anyone has had any similar issues.
I purchased an SPS200 last summer. With my first recordings, I  found digital spikes in each track (random intervals every few minutes). I was using a Mix Pre 6. I tried again indoors with a different setup (Allen and Heath board to DAW, no Mix Pre), same problem. I sent the mic back to Rode, the said they couldn't reproduce the problem but since the mic was under warranty they sent me a new one. I just took it out into the field (Mix Pre again) and found the same issues.
Thanks for any input.
I have a Pre Rode SPS200. Works great with a Mix Pre 6. Maybe see if the guys at Core Sound can calibrate it and maybe they will find an issue...
The Mix Pre 6 used to have weird artifacts at high sample rates... but apparently that has been solved.
On 3/13/2019 at 10:39 PM, JonG said:
I believe that Core Sound makes the Tetra mic, not the Rode mic.
That is true, however Core Sound does offer calibration services for the SPS200.
-Mike
2 hours ago, ramallo said:
I have two (2011 units) and I don't have any problem. But sometimes with high humidity I can had a "bump"
I wondered if it was humidity. I'm in Virginia where humidity tends to be the norm.
Also to KGraham045 and Mobilemike, thanks for the Core Sound suggestion. I've sent an inquiry to Core about that as well
