foliver Posted March 17, 2019 Report Share Posted March 17, 2019 Hello all. This night i need to build a strange bridge. first time for me. So i need to take the signal of a Comtek 72 RX and plug it to a sennheiser G3. I was making tests with standard cables, but they didn't work. Comtek doesn't turn on. So i'll build a pair of new jumpers. Someone has a diagram to do that? A 3.5 to XLR male cable can be of help to... I can figure out but i have not too mutch time to hang around. Thanks for your ideas! Fabian Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted March 17, 2019 Report Share Posted March 17, 2019 From the 72 RX to a G3 TX? You have to come out of the headphone jack on the RX with a 3.5mm mono plug. The XLR cable should be wired as follows, The wire from the tip goes to pin 2 of the XLR, the ground/shield of the 3.5mm goes to pin 1 & 3 creating an unbalanced signal path. Turn up the 72 RX output control and adjust the G3 TX input control. An XLR will not fit a Sennheiser G3 TX input as it's a 3.5mm TRS locking connector. The wiring for the 3.5mm G3 input cable is simple. If you're sending a mic level signal then it's tip to tip, if it's a line level signal then the tip of the 72 cable connects to the ring and you ground the tip to the sleeve. Quote Link to comment Share on other sites More sharing options...
foliver Posted March 17, 2019 Author Report Share Posted March 17, 2019 Hello Eric, long time without writing to each other. Thanks for save me! a hug from the south Fabian Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted March 18, 2019 Report Share Posted March 18, 2019 21 hours ago, foliver said: Hello Eric, long time without writing to each other. Thanks for save me! a hug from the south Fabian Fabian my old friend. How nice to hear from you once again. It's been a long time for sure. I hope this finds you in good health and spirits. and a hug from the north. Eric Quote Link to comment Share on other sites More sharing options...
