JJS
sample rate change of polyphonyc file
Hi,
I need to change sample rate of some polyphonic files from 44,1k to 48k and keep polyphony, metadata and time code.
any idea?
thanks
Any half decent NLE?
PT? (Not sure if Reaper keeps metadata...)
If that all is not possible, outsource?
(I can do it for sure...)
Why would you want it? Any editor who has to work with the files can do it without a problem.
(Unless you don't want to show them you've recorded 44.1 that is...)
Yes, WA can change the sampling rate, but it will NOT resample, hence the pitch and duration will change.
From 44.1 to 48 I would think that is not acceptable.
Hi Bouke,
Do you mean there's no problem editing clips with diferent sample rate in premiere?
I spend a entire day in a shoot recording 44.1k... and the editor will find clips in both sample rate 44.1k & 48k
14 hours ago, Bouke said:
No problem whatsoever.
(If he's on any half decent version...)
happy to ear that.
Thanks a lot!
