jwill Posted April 4, 2019 Report Share Posted April 4, 2019 I own 2 633s. I have an upcoming job where there are going to be 6 people seated at a u shaped table all talking. It will be lit with a china lantern overhead and there will be a tiffany lamp suspended overhead. Booms are out, I have 6 wireless, 4 block 19 and 2 block 20, but don't know if I want to run risk of intermod and dropouts. I am thinking of running 6 wired lavs, 3 into one 633 then out to the three line inputs of the other 633 and the other 3 into the mic inputs of the 2nd 633. I can send 1 & 2 out the XLR output and assign ch 3 to x1 out and into 2nd 633 ch 6. Any advice or thoughts on this topic? Quote Link to comment Share on other sites More sharing options...
ProSound Posted April 4, 2019 Report Share Posted April 4, 2019 I would run 3 hardwired lavs and 3 wireless to keep it all in one machine personally but your set up will work too or rent something else for the day Quote Link to comment Share on other sites More sharing options...
thenannymoh Posted April 4, 2019 Report Share Posted April 4, 2019 Unless you are stationed far away, I can't imagine you'll have dropout problems with lectro transmitters here...I use the FreqFinder app to avoid intermod problems, and spread over two blocks you won't have problems. Regardless, you can't go wrong with wired if they aren't up and down. Your dual 633 plan will work, and Dugan will definitely help. But to simplify, I would plan for all 6 on one 633 using wireless, but have the other 633 as backup in case you do have wireless problems. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted April 4, 2019 Report Share Posted April 4, 2019 K.I.S.S. and Dugan. Quote Link to comment Share on other sites More sharing options...
Stillweii Posted April 4, 2019 Report Share Posted April 4, 2019 Sounds like you know what to do in case the wireless route doesn’t work . I’d check my scan on block 19 before deciding . Quote Link to comment Share on other sites More sharing options...
jwill Posted April 4, 2019 Author Report Share Posted April 4, 2019 Thank you all for your advice and input...KISS is key!! It has me refocused!! Quote Link to comment Share on other sites More sharing options...
Jim Feeley Posted April 4, 2019 Report Share Posted April 4, 2019 8 minutes ago, jwill said: Thank you all for your advice and input...KISS is key!! Kill Idiodic Sound Setups? 😉 Quote Link to comment Share on other sites More sharing options...
CineStrega Posted April 4, 2019 Report Share Posted April 4, 2019 I use hardwired lavs a lot, but I'd be weary of mixing them with wireless since most systems have some latency. Just make sure you're on top of when people get up and sit down. Quote Link to comment Share on other sites More sharing options...
drpro Posted April 4, 2019 Report Share Posted April 4, 2019 +1 on FreqFinder app and Dugan. Both make your life a bit easier. Quote Link to comment Share on other sites More sharing options...
mikewest Posted April 5, 2019 Report Share Posted April 5, 2019 The only issue with hardwired lavs is the dynamic range can be wide and hard to handle. At least with wireless the compressor/limiters give you better control. mike Quote Link to comment Share on other sites More sharing options...
daniel Posted April 5, 2019 Report Share Posted April 5, 2019 4 hours ago, mikewest said: The only issue with hardwired lavs is the dynamic range can be wide and hard to handle. At least with wireless the compressor/limiters give you better control. mike +1. 633 has no limiters on I/Ps 4-6. Quote Link to comment Share on other sites More sharing options...
chrismedr Posted April 5, 2019 Report Share Posted April 5, 2019 1 hour ago, daniel said: +1. 633 has no limiters on I/Ps 4-6. well, since 4-6 are line level only, I'd look for a preamp that has limiters. I really like hardwired lavs, only trouble is keeping everybody aware that they are hooked up (I already have problems with that with one lav, don't want to imagine six) Quote Link to comment Share on other sites More sharing options...
daniel Posted April 5, 2019 Report Share Posted April 5, 2019 11 hours ago, chrismedr said: well, since 4-6 are line level only, I'd look for a preamp that has limiters. I really like hardwired lavs, only trouble is keeping everybody aware that they are hooked up (I already have problems with that with one lav, don't want to imagine six) Wonder how much more it would have cost to put limiters into any of these: http://www.filmtontechnik.de/en/products-from-kortwich/vcp-preamp/ https://www.pinknoise-systems.co.uk/pinknoise-sound-devices-633-3-channel-expander.html Quote Link to comment Share on other sites More sharing options...
Constantin Posted April 6, 2019 Report Share Posted April 6, 2019 11 hours ago, daniel said: Wonder how much more it would have cost to put limiters into any of these: http://www.filmtontechnik.de/en/products-from-kortwich/vcp-preamp/ https://www.pinknoise-systems.co.uk/pinknoise-sound-devices-633-3-channel-expander.html A lot more is my guess. So much so that SD decided to only include three Quote Link to comment Share on other sites More sharing options...
daniel Posted April 6, 2019 Report Share Posted April 6, 2019 13 minutes ago, Constantin said: A lot more is my guess. So much so that SD decided to only include three ...on the inputs with mic pres and p48 - pointless not to. Quote Link to comment Share on other sites More sharing options...
Constantin Posted April 6, 2019 Report Share Posted April 6, 2019 4 minutes ago, daniel said: ...on the inputs with mic pres and p48 - pointless not to. Yes, of course, but none on the line-ins Quote Link to comment Share on other sites More sharing options...
