ronmac Posted May 22, 2019 Report Share Posted May 22, 2019 Trew and B&H are both h showing $649USD Quote Link to comment Share on other sites More sharing options...
Vincent R. Posted May 26, 2019 Report Share Posted May 26, 2019 So a (first?) hands on example of the capabilities. Audio example starts at the 5:40 mark: Quote Link to comment Share on other sites More sharing options...
pillepalle Posted May 26, 2019 Report Share Posted May 26, 2019 Hopefully they deliver it with a pair of tweezers to be able to operate the unit Greetings Quote Link to comment Share on other sites More sharing options...
chrismedr Posted May 27, 2019 Report Share Posted May 27, 2019 7 hours ago, pillepalle said: Hopefully they deliver it with a pair of tweezers to be able to operate the unit yeah, knobs look awkward and the idea to cycle through menus with those tiny buttons is not very appealing. however.... the dual preamp + 32bit float looks very convincing! just imagine you have to do a car bag drop and simply don't have to worry about levels. I can well imagine that once post catches up, this will be the standard in all recorders in 10years time. would be interesting if Sonosax plans to do implement this with a firmware upgrade (if at all possible) chris Quote Link to comment Share on other sites More sharing options...
Olle Sjostrom Posted May 27, 2019 Report Share Posted May 27, 2019 While the thought of 32 bit and full dynamic range is cool and all, I still think that the target audience (single person video shooter, run and gun) is going to be disappointed. While the audio in that video is fine, thing is the mic is connected directly to the unit. Many video shooters have wireless systems that are inferior to the preamps of this unit, and the dynamic range of the recorder won't help then. Sure, for car rigs or other cramped rigs, it would be awesome. But still I imagine those video shooters buying this thinking all their audio will sound great and have no distortion and be "raw". And then they put their Rode wireless system on their talent with the wrong gain staging. Quote Link to comment Share on other sites More sharing options...
INARI Posted May 27, 2019 Report Share Posted May 27, 2019 The file format itself is 32bit float, but I think the actual dynamic range is around 140dB. Quote Link to comment Share on other sites More sharing options...
Alex Mitchell Posted May 27, 2019 Report Share Posted May 27, 2019 I’m impressed by that YouTube clip (where they pull usable audio from extremely loud and extremely quiet recordings) but I’m also curious what the results would be if you tried something similar with a NeverClip track off of a Nomad/Maxx/Deva24/Nova. Quote Link to comment Share on other sites More sharing options...
chrismedr Posted May 27, 2019 Report Share Posted May 27, 2019 8 hours ago, INARI said: The file format itself is 32bit float, but I think the actual dynamic range is around 140dB. which matches the maximum dynamic range of most microphones (and most sounds that don't make my ears bleed : ) sounds good enough for me. Quote Link to comment Share on other sites More sharing options...
engaudio Posted May 27, 2019 Report Share Posted May 27, 2019 13 hours ago, chrismedr said: however.... the dual preamp + 32bit float looks very convincing! just imagine you have to do a car bag drop and simply don't have to worry about levels. I can well imagine that once post catches up, this will be the standard in all recorders in 10years time. would be interesting if Sonosax plans to do implement this with a firmware upgrade (if at all possible) chris The SXR4+ already uses dual A/D's and CAN record at either 24 or 32Bit. That is why there is a US version, because of the "Zaxcom dual A/D patent issue".. See here: https://www.sonosax.ch/wp-content/uploads/2016/12/AUDIO_PATENTS.pdf I suppose the next question is, what will Zaxcoms response be to this Zoom dual A/D recorder? Quote Link to comment Share on other sites More sharing options...
INARI Posted May 27, 2019 Report Share Posted May 27, 2019 18 minutes ago, engaudio said: The SXR4+ already uses dual A/D's and CAN record at either 24 or 32Bit. That is why there is a US version, because of the "Zaxcom dual A/D patent issue".. See here: https://www.sonosax.ch/wp-content/uploads/2016/12/AUDIO_PATENTS.pdf I suppose the next question is, what will Zaxcoms response be to this Zoom dual A/D recorder? Probably there will be no response forever. if it works with the scheme different from NeverClip. There have been some models with dual ADCs that for increase dynamic range in the past.https://www.merging.com/products/interfaces/merging+anubis https://www.sony.jp/ic-recorder/products/PCM-D100/ Quote Link to comment Share on other sites More sharing options...
chrismedr Posted May 27, 2019 Report Share Posted May 27, 2019 1 hour ago, engaudio said: The SXR4+ already uses dual A/D's and CAN record at either 24 or 32Bit. I don't know the machine, so I might be missing something, but the manual only lists 24bit and there's no hint of 32bit (nor could I find any mention through google), let alone float (which are two different things, although they are usually used together) https://www.sonosax.ch/wp-content/uploads/2016/12/SXR4_um-hardware_eng.pdf Quote Link to comment Share on other sites More sharing options...
IronFilm Posted May 28, 2019 Author Report Share Posted May 28, 2019 6 hours ago, engaudio said: The SXR4+ already uses dual A/D's and CAN record at either 24 or 32Bit. That is why there is a US version, because of the "Zaxcom dual A/D patent issue".. See here: https://www.sonosax.ch/wp-content/uploads/2016/12/AUDIO_PATENTS.pdf I suppose the next question is, what will Zaxcoms response be to this Zoom dual A/D recorder? I'm guessing you own the European version of the SX-R4+ rather than the US version? Quote Link to comment Share on other sites More sharing options...
engaudio Posted May 28, 2019 Report Share Posted May 28, 2019 (edited) 7 hours ago, chrismedr said: I don't know the machine, so I might be missing something, but the manual only lists 24bit and there's no hint of 32bit (nor could I find any mention through google), let alone float (which are two different things, although they are usually used together) https://www.sonosax.ch/wp-content/uploads/2016/12/SXR4_um-hardware_eng.pdf Yep, the manual doesn't really hint at it but it can do 32bit float. Odd because the early release notes mentioned it.. Anyway, here's a screenshot confirming from a test recording I just made on my non US model SXR4+. Edited May 28, 2019 by engaudio grammer Quote Link to comment Share on other sites More sharing options...
JFtaper Posted May 28, 2019 Report Share Posted May 28, 2019 lots of discussion over here https://taperssection.com/index.php?topic=190161.0 Quote Link to comment Share on other sites More sharing options...
borjam Posted May 28, 2019 Report Share Posted May 28, 2019 9 hours ago, chrismedr said: I don't know the machine, so I might be missing something, but the manual only lists 24bit and there's no hint of 32bit (nor could I find any mention through google), let alone float (which are two different things, although they are usually used together) https://www.sonosax.ch/wp-content/uploads/2016/12/SXR4_um-hardware_eng.pdf Anyway it's better to make a distinction between the file format and the actual amount of information it contains. The actual amount of information stored by the recorder is determined by the properties of the A/D converters and the analog circuitry (and the microphone obviously) and it is much smaller than the total dynamic range that can be represented in 32 bit floating point. As @INARI pointed out, around 140 dB would be a very good value. So why 32 bit FP? It's a common sample format, you don't need to create a custom, say, 26 bit fixed point format. And floating point eliminates the need to adjust values in order to fit the more limited precision of fixed point. It's also much easier to handle when doing calculations (gain adjustments, etc). Of course it also offers a marketing benefit. Some readers will assume that being 32 bit FP it will have an almost infinite dynamic range. Quote Link to comment Share on other sites More sharing options...
INARI Posted May 28, 2019 Report Share Posted May 28, 2019 thank you. "We will not be too strict to preamp gain at field recording" It only works for that degree. And all of condenser microphones cannot escape brown noise in the air, and resistor that equipped in your machine has Johnson noise. So, our ears and equipments can not be used up even with 24 bit int. But I think it is a very good product considering the price. Quote Link to comment Share on other sites More sharing options...
LarryF Posted May 28, 2019 Report Share Posted May 28, 2019 For those of you who are curious, brown noise for mics is Brownian noise due to the motion of air molecules (Brownian motion). Sennheiser, years ago, showed that the noise floor of their RF condenser mics dropped when the mics were placed in a vacuum in a bell jar. Pretty damned impressive demonstration. Oddly enough, the young human ear is limited by Brownian motion. However, that has not been demonstrated in an evacuated bell jar. The only way to lower the Brownian motion noise, is to use larger diaphragms that increase the desired signal by the increased area and only increase the noise level by the square root of the increase of area. That's a reason why little tiny lavalieres don't have the low noise performance of large diaphragm mics. Johnson noise is the thermal noise in any resistor, even "perfect" ones, and at a given temperature, is inescapable. Good quality metal film resistors have noise levels very close to the theoretical limit for thermal noise. The only way to lower this noise level is to cool the resistor or device, sometimes being as extreme as using liquid helium. Best Regards, Larry Fisher Quote Link to comment Share on other sites More sharing options...
INARI Posted May 29, 2019 Report Share Posted May 29, 2019 Thanks. I mistakenly wrote "Brown motion" as "Brown noise" 😅 A microphone with 0dBA or less self noise was released before. The self noise was 0dBA in spec sheet when it was on sale. but nobody sings in space, so it was rewritten to 4dBA.https://www.lewitt-audio.com/microphones/lct-recording/lct-540-subzero Quote Link to comment Share on other sites More sharing options...
chrismedr Posted May 29, 2019 Report Share Posted May 29, 2019 5 hours ago, INARI said: So, our ears and equipments can not be used up even with 24 bit int. I think nobody here thinks that 32bit gives us better quality audio, I totally agree that with gain levels set properly a 24bit recording will be indistinguishable.. The benefit is not better quality, but that with proper dual amplifiers and float encoding it's simply impossible to mess up a recording due to improper gain settings. Now if that is any benefit or just useless tech depends a lot on the intended use. Most sound production mixers probably know how to set levels properly (and take pride of it), but I can still think of occasions where simply never having to touch the trim knob could be useful (lavs, car drop, stunt scenes, unsupervised nature recordings, concerts that I want to enjoy rather then worrying about levels etc). Quote Link to comment Share on other sites More sharing options...
daniel Posted May 29, 2019 Report Share Posted May 29, 2019 4 hours ago, chrismedr said: I think nobody here thinks that 32bit gives us better quality audio, I totally agree that with gain levels set properly a 24bit recording will be indistinguishable.. The benefit is not better quality, but that with proper dual amplifiers and float encoding it's simply impossible to mess up a recording due to improper gain settings. Now if that is any benefit or just useless tech depends a lot on the intended use. Most sound production mixers probably know how to set levels properly (and take pride of it), but I can still think of occasions where simply never having to touch the trim knob could be useful (lavs, car drop, stunt scenes, unsupervised nature recordings, concerts that I want to enjoy rather then worrying about levels etc). Is it fair to say a 6 I/P recorder this small needs to have 32bit FP because those pots are so impractical? And if a large part of the intended market is OMBers then a system that doesn't need constant adjustment (or even monitoring) of levels is also advantageous? I think aside from debatable improvements over noise floor, this recorder will bring 2 big things for the intended market: size and ease of use. Quote Link to comment Share on other sites More sharing options...
Boomboom Posted May 29, 2019 Report Share Posted May 29, 2019 … at 13:14 about the TC menu in Bluetooth mode… a hint: Timecode Systems. Ditch the box ! 😉 Quote Link to comment Share on other sites More sharing options...
IronFilm Posted May 29, 2019 Author Report Share Posted May 29, 2019 11 hours ago, LarryF said: For those of you who are curious, brown noise for mics is Brownian noise due to the motion of air molecules (Brownian motion). Sennheiser, years ago, showed that the noise floor of their RF condenser mics dropped when the mics were placed in a vacuum in a bell jar. Pretty damned impressive demonstration. Oddly enough, the young human ear is limited by Brownian motion. However, that has not been demonstrated in an evacuated bell jar. The only way to lower the Brownian motion noise, is to use larger diaphragms that increase the desired signal by the increased area and only increase the noise level by the square root of the increase of area. That's a reason why little tiny lavalieres don't have the low noise performance of large diaphragm mics. Fascinating! That is the coolest fact I learned today 9 hours ago, chrismedr said: but I can still think of occasions where simply never having to touch the trim knob could be useful (lavs, car drop, stunt scenes, unsupervised nature recordings, concerts that I want to enjoy rather then worrying about levels etc). Reality TV / docos / etc 1 hour ago, Boomboom said: … at 13:14 about the TC menu in Bluetooth mode… a hint: Timecode Systems. Ditch the box ! 😉 Nifty! Zoom has already paired with TCS before for their Ambisonics mic/recorder. Quote Link to comment Share on other sites More sharing options...
LarryF Posted May 29, 2019 Report Share Posted May 29, 2019 9 hours ago, INARI said: Thanks. I mistakenly wrote "Brown motion" as "Brown noise" 😅 [snip] Hi Inari, "Brown noise" is perfectly correct, similar to white noise or pink noise and is caused by Brownian motion. The scientist that Brownian motion was named after was Robert Brown, a botanist (!) (thanks Google). Brown noise is heavily weighted towards low frequencies. Starting with white noise, you can make pink noise with a complicated but gentle 3 dB per octave low pass filter. If you apply a steeper but simple 6 dB per octave low pass filter to white noise, you get brown noise. It's described as the rumbling noise of a large waterfall. Best Regards, Larry Fisher Quote Link to comment Share on other sites More sharing options...
Vincent R. Posted May 29, 2019 Report Share Posted May 29, 2019 7 hours ago, Boomboom said: … at 13:14 about the TC menu in Bluetooth mode… a hint: Timecode Systems. Ditch the box ! 😉 Rumor has it, the Tentacle BT system/access points are about to be made public in form of an SDK (software development kit) so third parties can sync to/from it (or develop for it) over... BT. Quote Link to comment Share on other sites More sharing options...
Mike Westgate Posted May 30, 2019 Report Share Posted May 30, 2019 On 5/29/2019 at 11:58 AM, LarryF said: For those of you who are curious, brown noise for mics is Brownian noise due to the motion of air molecules (Brownian motion). Sennheiser, years ago, showed that the noise floor of their RF condenser mics dropped when the mics were placed in a vacuum in a bell jar. Pretty damned impressive demonstration. Oddly enough, the young human ear is limited by Brownian motion. However, that has not been demonstrated in an evacuated bell jar. The only way to lower the Brownian motion noise, is to use larger diaphragms that increase the desired signal by the increased area and only increase the noise level by the square root of the increase of area. That's a reason why little tiny lavalieres don't have the low noise performance of large diaphragm mics. Johnson noise is the thermal noise in any resistor, even "perfect" ones, and at a given temperature, is inescapable. Good quality metal film resistors have noise levels very close to the theoretical limit for thermal noise. The only way to lower this noise level is to cool the resistor or device, sometimes being as extreme as using liquid helium. Best Regards, Larry Fisher Large condenser mikes used for music are usually close to a loud sound source. Electret personal mikes are usually close to to a person's mouth. The noise problem is usually not equipment based but location caused! With respect mike Quote Link to comment Share on other sites More sharing options...
