Dave Posted April 24, 2019 Report Share Posted April 24, 2019 Hi to Sound Devices Users, I wonder if anyone with a Sound Devices recorder has an idea of how long it generally takes to "recharge" an internal timecode/system battery from a depleted state? I have a MixPre 10T and some functions go haywire when the internal timecode/system battery is low or depleted. I can't find a way to know what this internal battery charge status is in any menu so am having to guess as to when the charge is proper and how long to leave it recharging. After reading different posts I am told that in order to get this internal battery up to an adequate or full charge, connecting to hirose wall power is recommended. The thing I am finding odd is that since the internal battery can only be charged when the MixPre is turned on, you must hook up to wall power and leave the unit turned on - overnight recommended by Sound Devices. Apparently the internal system/timecode battery can also be recharged when the unit is powered by L-mount sled battery power, but once again the unit must be powered on for an indeterminate duration to do so. Would anyone know how long this takes. Is it normal on other recorders that while you are charging the internal system/timecode battery you have to stay powered on and are effectively depleting the main power battery? Lastly, how long are these internal rechargeable systems batteries supposed to last? Other than having malfunctions set in, is there a way to keep on top of this system battery's status and performance? Thanks for any tips. As always, much appreciated. Cheers, Dave Quote Link to comment Share on other sites More sharing options...
Mungo Posted April 24, 2019 Report Share Posted April 24, 2019 As far as I know from 633, a few minutes charging time are enough to take advance of the timecode accuracy (blue light flashing) and the shutdown feature. The mixer must be turned on. If charging time seems to take longer, there may be an issue: battery end of life or battery cables internally loosened which once happend to my device. Don't have experience with MixPre though. Quote Link to comment Share on other sites More sharing options...
Mike Westgate Posted April 24, 2019 Report Share Posted April 24, 2019 When in doubt put a new battery in it, it's quite easy! mike Quote Link to comment Share on other sites More sharing options...
tourtelot Posted April 25, 2019 Report Share Posted April 25, 2019 Yep. If your T/C battery is causing you grief/uncertainty, replace it. It should work invisibly in the BG. D. Quote Link to comment Share on other sites More sharing options...
JonG Posted April 25, 2019 Report Share Posted April 25, 2019 How are people having these issues with such new devices? My 788T has never needed the TC battery changed and I bought it new eight years ago. Same with my 633. The only device I’ve had to change a TC battery for is a 702T that I purchased used and don’t know the history of. Quote Link to comment Share on other sites More sharing options...
Constantin Posted April 25, 2019 Report Share Posted April 25, 2019 1 hour ago, JonG said: My 788T has never needed the TC battery changed and I bought it new eight years ago. Same with my 633. Did you ever send your 788 to SD? I think they swap out the TC as a matter of course as it is a regular AA rechargeable will die eventually. 7 hours ago, Mike Westgate said: When in doubt put a new battery in it, it's quite easy! mike Don‘t know about the MixPre, but on the 633 this isn’t that easy at all. It‘s the buffer battery that holds TC for two hours and also facilitates the safe shutdown feature. What‘s easy to change is the RTC battery, but that isn’t a rechargeable battery, so it needs to be changed regularly. Quote Link to comment Share on other sites More sharing options...
Mike Westgate Posted April 25, 2019 Report Share Posted April 25, 2019 Get you! Sorry I did mean the RTC battery I think the buffer battery is a solder job so maybe it is expected to last longer Cheers mike Quote Link to comment Share on other sites More sharing options...
JonG Posted April 26, 2019 Report Share Posted April 26, 2019 On 4/24/2019 at 11:34 PM, Constantin said: Did you ever send your 788 to SD? I think they swap out the TC as a matter of course as it is a regular AA rechargeable will die eventually. Nope. It’s never needed servicing. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted April 26, 2019 Report Share Posted April 26, 2019 If you change internal batteries (that aren't soldered in) on any of our devices, it's a good idea to burnish the points where they make contact and add a drop of Deoxit contact cleaner to those connections. These circuits operate at such low current that any resistance at the contact points can be an issue. Quote Link to comment Share on other sites More sharing options...
Constantin Posted April 26, 2019 Report Share Posted April 26, 2019 8 hours ago, JonG said: Nope. It’s never needed servicing. Interesting. Well... the battery will die eventually Quote Link to comment Share on other sites More sharing options...
Chris Woodcock Posted April 26, 2019 Report Share Posted April 26, 2019 3 hours ago, Constantin said: Interesting. Well... the battery will die eventually As will everything else 🌍💥 Quote Link to comment Share on other sites More sharing options...
Constantin Posted April 27, 2019 Report Share Posted April 27, 2019 On 4/26/2019 at 9:52 PM, Chris Woodcock said: As will everything else 🌍💥 Of course. Some things sooner, some later Quote Link to comment Share on other sites More sharing options...
DeafDave Posted May 22 Report Share Posted May 22 It would be nice to be able to see the health/charge state of these internal batteries!! Did anyone find a guide about how to change the batteries in the MixPre10T series? I have found them for the 6 series alright but nothing for the mixpre recorders What are the batteries inside the MixPre10? Perhaps a 2032 but what is the rechargable? Someone mentioned an AA rechargable above? Quote Link to comment Share on other sites More sharing options...
