Frode L Hvatum Posted April 25, 2019 Report Share Posted April 25, 2019 Looking for something like this, but more durable. https://www.elfadistrelec.no/no/bnc-kabelkontakt-vinklet-marushin-electric-mnc-579ls/p/14627691?pos=1&origPos=1&origPageSize=10&p=cat-L2D_379527~cat-L3D_525369~cat-DNAV_PL_041004&q=*&prodprice=45.0&isProductFamily=true&campaign=&track=true Quote Link to comment Share on other sites More sharing options...
Karl Wasserman Posted April 25, 2019 Report Share Posted April 25, 2019 https://www.amphenolrf.com/112601.html Quote Link to comment Share on other sites More sharing options...
The Immoral Mr Teas Posted April 26, 2019 Report Share Posted April 26, 2019 Hey Karl, thanks for these too! Perfect for some future bag looms. Jez Quote Link to comment Share on other sites More sharing options...
Frode L Hvatum Posted April 26, 2019 Author Report Share Posted April 26, 2019 Thanks! How does the screw work? Is it a cover for the top of the connector? So you solder from the top/ back of the connector? The picture doesn´t seem to show the interesting part of this connector. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted April 26, 2019 Report Share Posted April 26, 2019 4 hours ago, Frode L Hvatum said: Thanks! How does the screw work? Is it a cover for the top of the connector? So you solder from the top/ back of the connector? The picture doesn´t seem to show the interesting part of this connector. There's a hole in the back that allows you to solder to the pin. Then the round cap is screwed in for full shielding. NOTE: You need the right crimp tool to do these properly. There are some inexpensive ones on eBay that work fine for low volume output. Quote Link to comment Share on other sites More sharing options...
Karl Wasserman Posted April 26, 2019 Report Share Posted April 26, 2019 Quote Link to comment Share on other sites More sharing options...
Johnny Karlsson Posted April 26, 2019 Report Share Posted April 26, 2019 20-inch cable with right angle connectors on both ends, for less than one of the above connectors alone: https://www.amazon.com/gp/offer-listing/B017SC2Z9Q/ref=dp_olp_new_mbc?ie=UTF8&condition=new Quote Link to comment Share on other sites More sharing options...
soundtrane Posted April 27, 2019 Report Share Posted April 27, 2019 5 hours ago, Johnny Karlsson said: 20-inch cable with right angle connectors on both ends, for less than one of the above connectors alone: https://www.amazon.com/gp/offer-listing/B017SC2Z9Q/ref=dp_olp_new_mbc?ie=UTF8&condition=new yes, but YMMV with this stuff from China... Quote Link to comment Share on other sites More sharing options...
Frode L Hvatum Posted April 30, 2019 Author Report Share Posted April 30, 2019 Thanks for the video. Very informative. So it is secured because the crimp grips the shield. Not exactly Neutrik level of strain relief. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted April 30, 2019 Report Share Posted April 30, 2019 5 hours ago, Frode L Hvatum said: Thanks for the video. Very informative. So it is secured because the crimp grips the shield. Not exactly Neutrik level of strain relief. A crimp collar is quite common on BNC connectors -- and various others, for that matter. With the right crimp tool it affords a high level of strain relief as well as RF integrity. Quote Link to comment Share on other sites More sharing options...
WrineX Posted September 13, 2019 Report Share Posted September 13, 2019 On 4/25/2019 at 5:06 PM, Karl Wasserman said: https://www.amphenolrf.com/112601.html this is the most standard crimp on BNC.. problem with these are the strain relieve (the crimp on portion) is rather small in length, an what almost every time happens is the cable will be still sitting fine in the crimp part. but since bending the cable outside the strain relieve still inflict tension on the inner core it will end up breaking near the solder joint. after a while the just get ripped out of the strain relieve to.. they shoudl have added a rubber strain relieve after the crimp part so it wont be able to bend so much that it is pulling on the inner core Quote Link to comment Share on other sites More sharing options...
