Dalilamahimself Posted April 30, 2019 Report Share Posted April 30, 2019 I am running into a frustrating issue with my new set up and I haven’t been able to find out Much about it on line because the DCHT is so new. I know I’m doing something wrong and hopefully someone here can point me in the right direction. I am trying to route just the boom to my boom op and the mix to my director - both of whom are monitoring through M2R’s. I am using a 788t with a CL-9. The DCHT is plugged into outputs 1 and 2. Right now I am trying to route all this through the 788 routing menu. Originally I routed all the inputs to the right channel and the boom to the left channel. Then on the M2R of the boom op I used the balance menu to balance to the Left side only. On the M2R of the boom op in the mix menu I set the mono left + right so the boom op hears just the left channel in both headphones. But when I change the mix on the cl-9 it’s still registering in the boom ops ears. Even though the routing on the 788 only routes to boom to the left channel. I’m sure I’m doing something simple and wrong. Any ideas of what it could be? Quote Link to comment Share on other sites More sharing options...
frankaudio Posted April 30, 2019 Report Share Posted April 30, 2019 Check direct out routing on 788 menu Quote Link to comment Share on other sites More sharing options...
Patrick Farrell Posted April 30, 2019 Report Share Posted April 30, 2019 On your boom op's M2R, leave the balance centered and in the mixer menu select mono Ch 1. Quote Link to comment Share on other sites More sharing options...
Dalilamahimself Posted April 30, 2019 Author Report Share Posted April 30, 2019 16 minutes ago, Patrick Farrell said: On your boom op's M2R, leave the balance centered and in the mixer menu select mono Ch 1. That was it. Thanks Patrick. Quote Link to comment Share on other sites More sharing options...
JonG Posted May 1, 2019 Report Share Posted May 1, 2019 For boom you may also send the pre fader channel Quote Link to comment Share on other sites More sharing options...
