Glyn Posted May 10, 2019 Report Share Posted May 10, 2019 Just looking in the Sound Devices 633 manual and noticed this on page 29: Quote For unbalanced connections, tie pin-3 to pin-1 of the XLR-3M connector of the cable. What does this mean? Are they advising that you somehow add a connection between pins 3 and 1 of the male end of the unbalanced XLR cable. If so how do you do this. Many thanks in advance. Quote Link to comment Share on other sites More sharing options...
Trey LaCroix Posted May 10, 2019 Report Share Posted May 10, 2019 This is typical for connecting an unbalanced signal to a balanced input. Take a piece of wire and solder it from pin 1 to pin 3. I use the extra wire attached to a resistor. Quote Link to comment Share on other sites More sharing options...
Glyn Posted May 10, 2019 Author Report Share Posted May 10, 2019 Many thanks @Trey LaCroix Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted May 10, 2019 Report Share Posted May 10, 2019 Easy way to unbalance is to split the ground into two legs, tin both and solder one one leg to pin one and the other to pin 3. Quote Link to comment Share on other sites More sharing options...
