Bearded headphones Posted May 11, 2019 Report Share Posted May 11, 2019 I’ve noticed that over the past few years of general abuse my HM butt plug unit has gotten “loose”- it rotates a bit after being plugged into a boom or mic, and with certain booms I get a bad connection sound when its rotated or not quite positioned correctly. Is there a way to tighten it? Can’t see any obvious way to disassemble the xlr connector portion of the unit. I’d love to try and tackle the issue without having to send it back to the mothership- anyone done this on their own before? Quote Link to comment Share on other sites More sharing options...
Constantin Posted May 11, 2019 Report Share Posted May 11, 2019 I have added a little o-ring to the XLR tip - such as the one found on a regular female XLR plug. Now it fits very tightly. If you’re problem is further down you may have to replace the XLR section which is not that expensive Quote Link to comment Share on other sites More sharing options...
