Sign in to follow this
Bearded headphones
Lectrosonics HM transmitter issues
I’ve noticed that over the past few years of general abuse my HM butt plug unit has gotten “loose”- it rotates a bit after being plugged into a boom or mic, and with certain booms I get a bad connection sound when its rotated or not quite positioned correctly. Is there a way to  tighten it? Can’t see any obvious way to disassemble the xlr connector portion of the unit. I’d love to try and tackle the issue without having to send it back to the mothership- anyone done this on their own before?
I have added a little o-ring to the XLR tip - such as the one found on a regular female XLR plug. Now it fits very tightly. If you’re problem is further down you may have to replace the XLR section which is not that expensive
