Sign in to follow this
yizhye20
Sound device 633 no display, only the yellow led light on
Hello everyone.
There is a problem that occurred on my 633. I plugged the battery in and turned on the machine. There is nothing showed on the screen, but a yellow led light was on. The device can not be turned off unless I force turned it off (long press menu) It never happened before. Would that because of the wingman accessory I just put on last week. Should I send it back to SD or there is any way to fix it myself.
I have not seen this in mine, but I would start by calling Sound Devices and see what they suggest.
I assume you are on the latest firmware and only use approved media...? Tried starting up without Wingman, or anything else plugged in?
