Attila Posted May 24, 2019 Report Share Posted May 24, 2019 Hi, a guy from a sound store told me, that there is a difference between the WISYCOM MTP40S & MTP41S in performance. The MTP40S should have a better performance and reliability. Can someone confirm this? Quote Link to post Share on other sites
ryanpeds Posted May 24, 2019 Report Share Posted May 24, 2019 There is no difference besides the fact that one is dual battery and one is single battery. Quote Link to post Share on other sites
Mattias Larsen Posted May 25, 2019 Report Share Posted May 25, 2019 16 hours ago, ryanpeds said: There is no difference besides the fact that one is dual battery and one is single battery. I thought that the bigger one had a limiter and also the possibility to provide phantom power with the right adapter? Quote Link to post Share on other sites
Attila Posted May 25, 2019 Author Report Share Posted May 25, 2019 Yes phantom power is right. But both have the limiter. An on the Wisycom Website the MTP40S is pictured with the linear function. The MTP41S is not. So does both have the linear mode? Quote Link to post Share on other sites
pindrop Posted May 25, 2019 Report Share Posted May 25, 2019 42 minutes ago, Attila said: Yes phantom power is right. But both have the limiter. An on the Wisycom Website the MTP40S is pictured with the linear function. The MTP41S is not. So does both have the linear mode? As far as I can see having promoted 'LINEAR' with a banner, Wisycom sloppily neglect to tell you what it is, which leads one to the conclusion that it might be just a promotion name. Even if you downoad the manual and search for 'linear' there's no results found. If that's how they do business, I'm put off right from the start! Quote Link to post Share on other sites
Attila Posted May 25, 2019 Author Report Share Posted May 25, 2019 After searching I found a Video that explain the linear function. It´s about avoiding intermodulation. It will be explained at 6:00 and here at 3:30 Sadly this function is not explained in the user manual... Quote Link to post Share on other sites
VAS Posted May 25, 2019 Report Share Posted May 25, 2019 Agree, Wisycom manuals isn't helpful at all. Quote Link to post Share on other sites
Daniel Ignacio Posted May 25, 2019 Report Share Posted May 25, 2019 I tried Wisycom once and their included manuals are indeed lackluster. Unfortunate despite the nice sound quality I got. When in doubt, dual-battery is better since it necessitates less battery changes. Quote Link to post Share on other sites
phenix Posted May 25, 2019 Report Share Posted May 25, 2019 THE single-battery transmitter presumably has a limiter but it has no menu option for limiter, so it can't be defeated. The dual battery version has limiter on and limiter off menu option. The maximum RF output on the single-battery version is 50mw while on my dual-battery transmitters it is 100 mw. There may be a higher-output version available. I don't have the latest firmware installed, so some of these details may have been changed with newer firmware. Quote Link to post Share on other sites
Attila Posted May 27, 2019 Author Report Share Posted May 27, 2019 So the Wisycom support answered : The only difference between 40 and 41 are the battery life, the RF max power (MTP41 can’t go up to 100mW) and it can’t power the PHA48 to supply phantom power, outside for these points MTP40 and 41 are absolutely the same range and audio wise. All the MTP41S in Band 7 (470-663Mhz) we produce now will feature the LINEAR technology. Quote Link to post Share on other sites
