Tony Johnson Posted May 30, 2019 Report Share Posted May 30, 2019 Hi, has anyone found a good solution for securing a zmt743 to the boom. I have a home made velcro option but it is hard to get on and off to change batteries. Any ideas would be appreciated. Thanks Tony Quote Link to comment Share on other sites More sharing options...
Matthias Richter Posted May 30, 2019 Report Share Posted May 30, 2019 47 minutes ago, Tony Johnson said: Hi, has anyone found a good solution for securing a zmt743 to the boom. I have a home made velcro option but it is hard to get on and off to change batteries. Any ideas would be appreciated. Thanks Tony Do you mean a 743 OR a ZMT?? Quote Link to comment Share on other sites More sharing options...
Constantin Posted May 30, 2019 Report Share Posted May 30, 2019 If it is ZMT then Sound Guys Solutions have got a pretty good option. Fast on and off and very light Quote Link to comment Share on other sites More sharing options...
Matthias Richter Posted May 30, 2019 Report Share Posted May 30, 2019 the SGS needs a holder for every pole / suspension no? My DIY solution converts the ZMT to a self contained plug on. More cost effective... Quote Link to comment Share on other sites More sharing options...
Tony Johnson Posted May 31, 2019 Author Report Share Posted May 31, 2019 2 hours ago, Matthias Richter said: Do you mean a 743 OR a ZMT?? its a 743 and there doesn't seem to be an elegant solution that i have seen Quote Link to comment Share on other sites More sharing options...
Apcki Posted May 31, 2019 Report Share Posted May 31, 2019 I've seen people use the ktek squid as well. Quote Link to comment Share on other sites More sharing options...
Matthias Richter Posted May 31, 2019 Report Share Posted May 31, 2019 Gene Martin mod to the cone? Quote Link to comment Share on other sites More sharing options...
Constantin Posted May 31, 2019 Report Share Posted May 31, 2019 What’s the problem? I just put it into the XLR holder of the mic mount. With an additional o-ring this works ok. 8 hours ago, Matthias Richter said: the SGS needs a holder for every pole / suspension no? My DIY solution converts the ZMT to a self contained plug on. More cost effective... No, it attaches to the tip just like the Ambient QAT, for example. It’s very easy and quick to move it from pole to pole. What does your DIY solution look like? Quote Link to comment Share on other sites More sharing options...
Geluidloopt Posted June 4, 2019 Report Share Posted June 4, 2019 Neutrik Locking XLR straight onto the mic mount Quote Link to comment Share on other sites More sharing options...
Tony Johnson Posted June 4, 2019 Author Report Share Posted June 4, 2019 13 minutes ago, Geluidloopt said: Neutrik Locking XLR straight onto the mic mount They look great what does the other end look like? Quote Link to comment Share on other sites More sharing options...
Geluidloopt Posted June 4, 2019 Report Share Posted June 4, 2019 On top of the pole Quote Link to comment Share on other sites More sharing options...
Tony Johnson Posted June 4, 2019 Author Report Share Posted June 4, 2019 classy, i must look at those Quote Link to comment Share on other sites More sharing options...
Tony Johnson Posted June 4, 2019 Author Report Share Posted June 4, 2019 13 hours ago, Geluidloopt said: On top of the pole Hi, Do you have the model number of these please/ io cannot find the adapter part on the neutrek website thanks tony Quote Link to comment Share on other sites More sharing options...
Geluidloopt Posted June 5, 2019 Report Share Posted June 5, 2019 Hi, The neutrik part is : https://www.neutrik.com/en/product/nc3fx-spec However it screws in a custom ring i built, ie the black cone part in the picture. This allows easy replacement of the connector when it's worn. Quote Link to comment Share on other sites More sharing options...
Jason Todd Posted June 7, 2019 Report Share Posted June 7, 2019 You can also buy a pre-made version of the Zaxcom Analog Cone that Sound Guy Solutions makes. If your local dealer carries Sound Guy Solutions Products, have them inquire about purchasing or just reach out to Gene Martin at Audio Dept in Burbank. Quote Link to comment Share on other sites More sharing options...
Gene Martin Posted July 6, 2019 Report Share Posted July 6, 2019 Sound Guys Solutions available in all analog and AES options. Quote Link to comment Share on other sites More sharing options...
efksound Posted July 9, 2019 Report Share Posted July 9, 2019 On 6/5/2019 at 8:57 AM, Geluidloopt said: However it screws in a custom ring i built, ie the black cone part in the picture @Geluidloopt Is the custom ring available to buy somewhere? Quote Link to comment Share on other sites More sharing options...
malflo87 Posted July 9, 2019 Report Share Posted July 9, 2019 I have printed something myself which works pretty well, because it is really easy to attach the transmitter to different booms and still allows for easy access to all parts of the transmitter.The idea is that I can also print different enclosures for different type of transmitters and can rig all the transmitters easily in a car. I'm building vers. 2.0 for my longer booms with internal wiring and moving it to the bottom of my boom (obviously not the real bottom end but somewhere on the handle). I may sacrifice some range but that is not a big issue as long as the boom handles nicely. Quote Link to comment Share on other sites More sharing options...
Tony Johnson Posted August 14, 2019 Author Report Share Posted August 14, 2019 On 7/7/2019 at 8:40 AM, Gene Martin said: Sound Guys Solutions available in all analog and AES options. Hi Gene, i have searched the sound guys solutions website and cannot find this. Tony Quote Link to comment Share on other sites More sharing options...
