Manel Posted June 3, 2019 Report Share Posted June 3, 2019 Hello. I'm trying to sync a Blackmagic Pocket camera with a Nanolockit. I have no problems when music a Tentacle Sync as it reads the TC straight away and sends it to the TC of the camera. But when pugging the Nano, it sends the TC to one of the audio tracks, it doest read is as TC in, which is not ideal. Have double checked the settings of the nano on the Ambient toolbox app. Frame rate is set and all the setting seem to be correct. Has anyone found a similar problem? Any ideas? Cheers everyone. Quote Link to comment Share on other sites More sharing options...
Olle Sjostrom Posted June 3, 2019 Report Share Posted June 3, 2019 Maybe the output level of the nano is either too low or too high for the black magic so it doesn't see it as TC. Can you adjust the output level of the nano? Quote Link to comment Share on other sites More sharing options...
Dalton Patterson Posted June 3, 2019 Report Share Posted June 3, 2019 17 minutes ago, Olle Sjostrom said: Can you adjust the output level of the nano? Yes!!!, Hold top button and press down middle button to turn down, hold middle button and press top button to turn up. Quote Link to comment Share on other sites More sharing options...
Manel Posted June 3, 2019 Author Report Share Posted June 3, 2019 I don't think is that. When you connect the Tentacle it shows straight as TC in and EXT TC on the camera. When connecting the NanoLock it goes straight into the audio track which is a bummer. Not sure. Played with the output level from the locket before and nothing changed. Emailing Mr. Ambient to see if I can get an answer before Tuesday next week as we start our shoot. Thanks for the replies so far Quote Link to comment Share on other sites More sharing options...
IronFilm Posted August 21, 2019 Report Share Posted August 21, 2019 Are you feeding it to the same audio port as before? (as the BMPCC4K/6K has more than one) Quote Link to comment Share on other sites More sharing options...
Manel Posted October 3, 2019 Author Report Share Posted October 3, 2019 Hello. As usual is an operator problem. Turns out the FPS on the camera were set up to 24. Once fixed and connecting the Nano to the computer to check frame rates (I didn't know you had to connect the Nano to the computer to access a menu http://ambient.de/en/downloads/) There you go. All the Synch with the Black Magic Pocket cameras was great. Very easy to use. Thanks guys Quote Link to comment Share on other sites More sharing options...
JonG Posted October 12, 2019 Report Share Posted October 12, 2019 I just did a shoot with probably one of the most ridiculous setups I’ve ever seen. We had three pocket cameras, and they wanted TC in on the audio jack because they can read it as LTC (which is a pretty cool feature), but seriously, at what point do we just go back to using ENG cameras? Quote Link to comment Share on other sites More sharing options...
Allen Rowand Posted October 12, 2019 Report Share Posted October 12, 2019 At first glance I thought this was an Ursa! Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted October 12, 2019 Report Share Posted October 12, 2019 I'd say that my clients that have bought into the Black Magic mini camera deal are not going back unless they want to shoot biggo 8k stuff like Monstro or Venice. So I've gotten used to the BM multirigs. Quote Link to comment Share on other sites More sharing options...
JonG Posted October 12, 2019 Report Share Posted October 12, 2019 2 minutes ago, Allen Rowand said: At first glance I thought this was an Ursa! That’s what I thought we were going to be using. The person that hired me was not in the least bit technical, so I showed up and the AC gave me the rundown after expecting that I had been informed on what we were using and the workflow. The DP had a couple of first gen Tentacles that wouldn’t sync properly, and these cameras had a hard time reading their TC. I use the new Denecke JB-1’s but didn’t have the right cables because nobody has ever asked me to run TC into a DSLR. But we used the DPs tentacle cables and everything worked flawlessly after that. Quote Link to comment Share on other sites More sharing options...
IronFilm Posted October 17, 2019 Report Share Posted October 17, 2019 On 10/13/2019 at 11:45 AM, JonG said: We had three pocket cameras Sweeeeetttttt! Those are photos there of the brand new (just came out a few weeks ago, if that!) Blackmagic Pocket Cinema 6K S35 camera. (yes, you read that right, they're 6K! Not 4K like the old version) Quote Link to comment Share on other sites More sharing options...
