480sound Posted June 20, 2019 Report Share Posted June 20, 2019 Is there a way to get the Sound Report from the HD on a 788? When you create the report, it saves it to the HD and the CF card. When you back up the Folder on the HD with the report in it, it does not copy over the report to whatever your backing up to, or so it seems. It only copies the Report over the one time you create it to the CF card. Quote Link to comment Share on other sites More sharing options...
Constantin Posted June 20, 2019 Report Share Posted June 20, 2019 Instead of using the „copy files to ext“ or whatever, connect the 788 as an external drive to your computer. Then you can just grab all the files you need. This way is also much faster Quote Link to comment Share on other sites More sharing options...
