Allen Rowand Posted June 21, 2019 Report Share Posted June 21, 2019 I need to make an access hole into a pocket on an AO-1X; is there a better way than just making an X incision with a razor? I really don't understand why there isn't a passthrough between the outer side pockets and the battery pockets. This would allow cables to run from the RF pocket though the battery pocket and into the main body. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted June 21, 2019 Report Share Posted June 21, 2019 I hear you. You do what you gotta do, maybe singe the cut fabric with a lighter so it won't unravel. Quote Link to comment Share on other sites More sharing options...
David Waelder Posted June 22, 2019 Report Share Posted June 22, 2019 You might try using one of the circular cutting punches that comes with a set of grommet tools. These are available in any good hardware store and are sufficiently inexpensive that purchasing a kit for this sole application would not be unreasonable. Before buying anything, ascertain that you could get a punch into position where you need a hole and also strike it with a hammer either directly or through some material. I haven’t tried it on a bag but I think it worth a look. David Quote Link to comment Share on other sites More sharing options...
Nate C Posted June 22, 2019 Report Share Posted June 22, 2019 I've used an old soldering iron to make holes in bags in the past. Quote Link to comment Share on other sites More sharing options...
Allen Rowand Posted June 22, 2019 Author Report Share Posted June 22, 2019 Thanks for the ideas- I put the cutting blade on my butane soldering iron and cut it like butter: Now I can pass the power and signal for my receivers inside the main bag. Quote Link to comment Share on other sites More sharing options...
Jim Feeley Posted June 22, 2019 Report Share Posted June 22, 2019 Blade in a soldering iron was what I was going to suggest; I learned from modifying stuff packs and harnesses back in my mountaineering days... If it makes sense, maybe rub the fabric a bit more with the blade (or any tip really, but why mess up a good one?) to give the fabric a little extra melt-seal. Looks good! Quote Link to comment Share on other sites More sharing options...
daniel Posted June 23, 2019 Report Share Posted June 23, 2019 Nice work Allen. I took a pair of fabric shears to a KTEK Junior the other day. I wanted to do this ages ago but delayed because there was no way of doing it nicely. Probably cut away the 2 small black sections with the zips and seal the other edges by gluing webbing or rubber profile to them. Having a fold down flap for front display RX really works. It would have been nice if the bag had been more considerably designed for use with such a ubiquitous format of receiver but i suppose we're all meant to use top display RX, all of the time. Quote Link to comment Share on other sites More sharing options...
Mike Westgate Posted June 23, 2019 Report Share Posted June 23, 2019 Yep a punch or a scalpel then use a soldering iron to seal the edges mike Quote Link to comment Share on other sites More sharing options...
WrineX Posted September 13, 2019 Report Share Posted September 13, 2019 best would be punching.. but such a large hole might be hard to get a die for cutting is an option but you either have to stitch the edges, or depending on the material go beserk with a lighter melting the edge so it wont unravel. not the most pretty way but it works ! Quote Link to comment Share on other sites More sharing options...
Elusive Sounds Posted September 14, 2019 Report Share Posted September 14, 2019 On 6/23/2019 at 8:38 AM, daniel said: Nice work Allen. I took a pair of fabric shears to a KTEK Junior the other day. I wanted to do this ages ago but delayed because there was no way of doing it nicely. Probably cut away the 2 small black sections with the zips and seal the other edges by gluing webbing or rubber profile to them. Having a fold down flap for front display RX really works. It would have been nice if the bag had been more considerably designed for use with such a ubiquitous format of receiver but i suppose we're all meant to use top display RX, all of the time. What is going on on those Sennheiser receivers? Modded with two output connectors? Quote Link to comment Share on other sites More sharing options...
Allen Rowand Posted September 14, 2019 Author Report Share Posted September 14, 2019 6 hours ago, Elusive Sounds said: What is going on on those Sennheiser receivers? Modded with two output connectors? The 500 series and higher have a headphone output on the receiver. Quote Link to comment Share on other sites More sharing options...
