KISHOR CHAUHAN Posted August 31, 2019 Report Share Posted August 31, 2019 Directivity Omni directional Transducer Self-polarized condenser Frequency range 50Hz – 20kHz Sensitivity (nominal at 1kHz) 17.8mV/Pa (-35dB,0dB=1V/Pa) Equivalent noise level (A-weighted) 28dB-A Max SPL (1% THD) 127dB SPL. Output impedance at 1KHz 180 ohms Powering +48±4V phantom Current consumption less than 2.2mm Where do I find this Correspondance specification capsule. I need to buy some Quote Link to comment Share on other sites More sharing options...
The Immoral Mr Teas Posted September 2, 2019 Report Share Posted September 2, 2019 Where did you find it, Kishor? The specifications that is? It might well be a DPA 4060 excepting it doesn't actually need the 48v but that would be an expensive answer if the specs were for something much cheaper. Jez Quote Link to comment Share on other sites More sharing options...
NathanWBS Posted September 2, 2019 Report Share Posted September 2, 2019 Those are the specs for a Sanken COS-11D with the P48 XLR barrel. Regards, Nathan. Quote Link to comment Share on other sites More sharing options...
