dougafresh Posted October 1, 2019 Report Share Posted October 1, 2019 Hey folks! I'm trying to figure out the best Zaxnet antenna for my Nomad. Seeking the best compromise between (1) decent signal range (2) unobtrusive form factor in the bag and (3) minimal stress on the Nomad's antenna mount. I've been using an antenna that's ~4 inches sticking straight up (pictured), but have had some issues with my bag and harness putting pressure on it, causing the mount to loosen. Would appreciate any advice. Thanks! Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted October 1, 2019 Report Share Posted October 1, 2019 A short extension cable from the connector to the antenna. Quote Link to comment Share on other sites More sharing options...
Shastapete Posted October 1, 2019 Report Share Posted October 1, 2019 http://www.l-com.com/wireless-antenna-24-ghz-5-dbi-omni-blade-antenna-sma-male-connector I just ordered one of these, planning to loop the antenna through the webbing on the front of my Ktek bag. With a right angle adapter on the SMA it should both get the antenna out into the open as well as take the stress off of the connector Quote Link to comment Share on other sites More sharing options...
DennisT Posted October 9, 2019 Report Share Posted October 9, 2019 I use one of these, in the front pouch of my bag. Have to put your own connector on though. I believe they sell a wired version on ebay. https://www.wa5vjb.com/products6.html Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted October 9, 2019 Report Share Posted October 9, 2019 On 10/1/2019 at 11:16 AM, Shastapete said: http://www.l-com.com/wireless-antenna-24-ghz-5-dbi-omni-blade-antenna-sma-male-connector I just ordered one of these, planning to loop the antenna through the webbing on the front of my Ktek bag. With a right angle adapter on the SMA it should both get the antenna out into the open as well as take the stress off of the connector Pete What were your results? Quote Link to comment Share on other sites More sharing options...
Apcki Posted October 9, 2019 Report Share Posted October 9, 2019 You could also look into Lectro jointed antenna. https://www.locationsound.com/lectrosonics-amj-color-coded-whip-antenna-1365¤cy=USD&language=en?gclid=Cj0KCQjwivbsBRDsARIsADyISJ_PHkNDP9RrorP0CKkvwWsNmg5Ht0eICEVYcrCRngl5NoOSUd0t6dMaAuEyEALw_wcB Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted October 9, 2019 Report Share Posted October 9, 2019 3 minutes ago, Apcki said: You could also look into Lectro jointed antenna. https://www.locationsound.com/lectrosonics-amj-color-coded-whip-antenna-1365¤cy=USD&language=en?gclid=Cj0KCQjwivbsBRDsARIsADyISJ_PHkNDP9RrorP0CKkvwWsNmg5Ht0eICEVYcrCRngl5NoOSUd0t6dMaAuEyEALw_wcB Not a the same antenna. There is difference between both. Off course it will work but not optimal. There are a lot of 2.4gHz antennas available just make sure it is not reversed polarity. Digikey is a good source. Or Lcom You can also just point the antenna down. Quote Link to comment Share on other sites More sharing options...
Shastapete Posted October 9, 2019 Report Share Posted October 9, 2019 9 hours ago, Jack Norflus said: Pete What were your results? haven't had a chance to test it yet, my work for the last few months have all been interview or simple doc where I'm within a few feet of talent and have just continued using the rubber duck Quote Link to comment Share on other sites More sharing options...
azw Posted October 9, 2019 Report Share Posted October 9, 2019 https://shop.hak5.org/products/long-range-wifi-kit Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted October 9, 2019 Report Share Posted October 9, 2019 6 hours ago, azw said: https://shop.hak5.org/products/long-range-wifi-kit I doubt this makes any significant difference if any at all. Quote Link to comment Share on other sites More sharing options...
Mike Robertson Posted October 10, 2019 Report Share Posted October 10, 2019 Why do you think it wouldn’t help? Just curious, I don’t know too much about WiFi signal boosting. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted October 10, 2019 Report Share Posted October 10, 2019 7 hours ago, Mike Robertson said: Why do you think it wouldn’t help? Just curious, I don’t know too much about WiFi signal boosting. Through the years I have not seen any passive solutions making any difference. You can try a bigger antenna and it makes a little difference. Quote Link to comment Share on other sites More sharing options...
Shastapete Posted October 10, 2019 Report Share Posted October 10, 2019 That hak5 link is a .8 watt amplifier, so I'm sure it'll help Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted October 11, 2019 Report Share Posted October 11, 2019 16 hours ago, Shastapete said: That hak5 link is a .8 watt amplifier, so I'm sure it'll help I did not see that it has a little power input. so it is not passive. Still those specks look like advertising mumbo jumbo. Do try it. Maybe it helps. Quote Link to comment Share on other sites More sharing options...
azw Posted October 11, 2019 Report Share Posted October 11, 2019 It works. I certainly do get increased range - and many less complaints from IFB users. 🙂 Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted October 11, 2019 Report Share Posted October 11, 2019 5 hours ago, azw said: It works. I certainly do get increased range - and many less complaints from IFB users. 🙂 Still not ideal to use 2.4gHz for ifb. Also freeze some sperm if you want to have some kids in the future. Quote Link to comment Share on other sites More sharing options...
ramallo Posted October 12, 2019 Report Share Posted October 12, 2019 Not for bag, I have nice results with high directional antennas such as the 2.4 CP Beam from RF Venue Quote Link to comment Share on other sites More sharing options...
luis66666 Posted January 22 Report Share Posted January 22 On 10/9/2019 at 11:18 AM, azw said: https://shop.hak5.org/products/long-range-wifi-kit What range do you get with this?. Are you using erx's? Quote Link to comment Share on other sites More sharing options...
