BVS Posted June 6, 2009 Report Share Posted June 6, 2009 I have seen a few of these in use....seems an excellent solution..anyone using these regularly..and if so..how are they constructed... Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted June 6, 2009 Report Share Posted June 6, 2009 I have seen a few of these in use....seems an excellent solution..anyone using these regularly..and if so..how are they constructed... Are you refering to alligator clips with a 3-4mm post to hold the lav? Eric Quote Link to comment Share on other sites More sharing options...
BVS Posted June 6, 2009 Author Report Share Posted June 6, 2009 No Eric..not the obvious ones used for TV..no these are used under clothing as a means of creating space and having no rubbing or clothes movement. Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted June 6, 2009 Report Share Posted June 6, 2009 No Eric..not the obvious ones used for TV..no these are used under clothing as a means of creating space and having no rubbing or clothes movement. Ah, ok I know what you mean. They are called birdcages. I've seen pictures of homemade ones only. Eric Quote Link to comment Share on other sites More sharing options...
BVS Posted June 6, 2009 Author Report Share Posted June 6, 2009 As near as I can work out,they have a flat bar that is turned up at either end on a 45 degree angle and each end is then flattened off parallel to the base bar....a bit like an inverted drawer handle in your kitchen...it looks like it is made of a something light in weight and the mic attaches to the base by some means that isolates it mechanically from the bar.It could be made of plastic,rubber,or something light....the mic sits in the inverted bar...its looks as tho it might be about an inch and a half long and a quarter inch wide.....the two ends attach to the shirt or clothing and a space is created for it to sit in and work...I have seen it briefly on several TV shows,some of them from England....it works very well in a chefs outfit....you can actually touch the fabric above the mic and it is pretty quiet..as you can see...I have it fairly clear what it looks like but would be interested to hear from anyone who is using this. Quote Link to comment Share on other sites More sharing options...
Fernando Posted June 7, 2009 Report Share Posted June 7, 2009 can anyone scketch it please? Quote Link to comment Share on other sites More sharing options...
