raidopedak Posted January 16, 2020 Report Share Posted January 16, 2020 I thought I'd share my opinions on this lightweight battery I came across. Introduction: This is a mini V-lock battery called the FXLion Nano One. It has D-tap, USB-A and USB-C for powering various devices. It's very flexible as it can be charged in a standard V-lock charger, via D-tap, AND USB! So I recently upgraded from the MixPre-6 to a MixPre-10 II and needed a "real" battery instead of a USB power bank. Since I have various video gear anyway, I wanted something I could throw on a LED-light if needed etc. Performance: I tested an "average" use case on the MixPre-10, recording 2 Phantom mics, 2 radio mics, and the LR Mix. After a little more than 6 hours and 30 minutes of recording, the battery started flashing as the voltage dropped below 12V. I'm sure it could have squeezed out a few more minutes but I wouldn't risk it. I was using it with a D-tap to 4-pin Hirose cable. So a pair of these would get you through a production day, especially if you can keep the other one charging. Your mileage will vary depending on the gear you're powering, of course. Conclusion: It's not exactly a low-budget solution (I paid about 140€ excl. VAT per one), however, you can get away without buying a separate charger / battery cups etc. I think it's a nice intermediate alternative to the NP / smart battery systems on smaller bag setups. I hope at least one of you finds this useful or interesting. 🙂 Thanks! Quote Link to comment Share on other sites More sharing options...
bary555 Posted January 16, 2020 Report Share Posted January 16, 2020 This looks great. I have to test one. Looks like it could power my mixpre 6 and 833. Where i Eu did you buy it? Quote Link to comment Share on other sites More sharing options...
raidopedak Posted January 16, 2020 Author Report Share Posted January 16, 2020 1 hour ago, bary555 said: Where i Eu did you buy it? I got it from CVP. No shipping problems either, they send batteries via road transport. Quote Link to comment Share on other sites More sharing options...
lakusek Posted May 23, 2021 Report Share Posted May 23, 2021 I tested the 98Wh model yesterday with Mixpre 10T, 1 48V ph channel and 7 line channels armed (but not recording), LED and LCD on the brightest settings, and it lasted for around 13 hrs. Started at 10:50 with 16.2V left over and battery started to flash at 23:20 with voltage going under 12V. Quote Link to comment Share on other sites More sharing options...
