RadoStefanov Posted February 12, 2020 Report Share Posted February 12, 2020 My favorite contribution to Nova is becoming a reality. This is a game changer for reality bag mixers! it uses Bias voltage to enable the output to activate Push to talk on the walkie. Gene Martin is making me hd26 with a mic that will be connected to Nova and I can use the microphone and com to enable the walkie. I have been routing the walkie to my mixer/recorder for a very long time and now I don’t even need to use the walkie microphone and bring it to my mount. Everything is integrated and eliminates the need for those PTT walkie microphones. Quote Link to comment Share on other sites More sharing options...
osa Posted February 12, 2020 Report Share Posted February 12, 2020 i just discovered this with a fw update howy made for media cards. this is incredible. this is a major plus. that is great work Rado Quote Link to comment Share on other sites More sharing options...
cameronlenart Posted March 8, 2020 Report Share Posted March 8, 2020 I am wanting to set up walkie integration with my Nova but am getting a bit confused... As I see it there are two options: 1.) I can buy mic that attaches to my HP and plugs into the 'mic' 3.5mm on the Nova then route this to output 6 to the walkie and have a return from the walkie into return1/2 of the Nova. Pressing the com button should open the walkie. 2.) Glenn mentioned that he has successfully used a URX100 lanyard to the Nova. He said the PTT button on the lanyard was functional. He also said the lanyard needs to be connected to output 6 and return 1/2 for 2 way communication. Does this mean the lanyard TRRS connector can be split into mic and HP then plugged into the 3.5mm mic connector and routed to output 6 the same as I would do with the external mic? And the PTT button on the lanyard would be functional? Quote Link to comment Share on other sites More sharing options...
The Documentary Sound Guy Posted August 11, 2023 Report Share Posted August 11, 2023 Rado, where did you source an input cable / connector to interface the Nova with the radio? I'm happy to build my own cable, but I can't find any sources for the bare connectors, and the only cable I've found that is remotely close is intended for the URX: https://www.gothamsound.com/product/ta5f-motorola-m1-urx100-cable Nothing against Gotham, but I'd prefer to order from a Canadian source if I can; importing individual items is a nightmare for paperwork. Also, I'd prefer to build a cable that has a breakout for Out5 at the same time. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted August 11, 2023 Author Report Share Posted August 11, 2023 Gene from audio dept makes mine. Quote Link to comment Share on other sites More sharing options...
