src & micplexer2
hi
I have a question
I am a user who mainly uses hma plug-on in src (B1).
There is too much frequency interference these days.
Walkie-talkie frequency (403 ~ 470MHz) frequency interference
ARRI WCU-4 (2.4KHz) frequency interference
Teradek Bolt 3000 (5khz) frequency interference
Avoid these frequency interferences
zaxcom micplexer2 trying to buy
1.src & micplexer2
Want to know if it's okay to use it in combination?
What I want is not important that the signal goes far
It is a priority that you do not receive frequency interference from other equipment.
2.src@PSC RF Multi SMA (470-700 MHz)
I wonder what this combination is like
3. Be sure to let me know which of them is better to buy
micplexer2
The Micplexer II has a 35 MHz wide window that will do exactly what you want to do. It will only let in RF in the range you want to receive. The micplexer can be used with any brand of receiver. If you can do a test with both and see how close you can come to the receiver before it is effected with both products. The difference will be
The PSC from our tests adds gain to unwanted signals  (460 walkies) making a bad situation worse as it has no filtering to my knowledge.
Glenn
