Lucan Posted April 14, 2020 Report Share Posted April 14, 2020 Hi everyone! Long time lurker, first time poster here - this forum has been an unbelievable source of information and I want to thank you all for being such a kind community of pros! I hope you’re all keeping well during these uncertain times. I have a question about Zaxnet timecode. The gear in question includes: SD 633 (master clock) TrxCL3 Camera Link 3x ERX’s RX200 As a test, I set the 633 to Rec Run and reset the TC to 00:00:00:00. The CL3 is auto jammed to the 633, and in turn jams the ERX’s and the RX200. What happens, though, when everything is jammed, is the 633 is at 00:00:00:00, but the CL3 is at 00:00:00:02 ERX’s are at 00:00:00:02 RX200 is at 00:00:00:04! (Via UHF, not Zaxnet) No matter how many times I reset the entire system, this is the result. I am wondering if this is only a screen display discrepancy or if the actual timecode is not synced? If any experienced Zaxcom users might be able to chime in, I’d be hugely grateful! Thanks! Quote Link to comment Share on other sites More sharing options...
evarsimon Posted April 19, 2020 Report Share Posted April 19, 2020 I do something similar, except my TC comes out of a Maxx into the IFB board of a QRX235, might just be the display. I run 3 cameras often and I also edit, and the sync is not off. Quote Link to comment Share on other sites More sharing options...
sciproductions Posted April 19, 2020 Report Share Posted April 19, 2020 Just out of curiosity, when you put it on free run does it do the same thing? I.e. 2 frames off? On the RX200 have you checked your Zaxnet settings that there isn't timecode frame offset? Quote Link to comment Share on other sites More sharing options...
joinwooHK Posted April 21, 2020 Report Share Posted April 21, 2020 i suggest u Record a beep to all and see is it there offset on recorded file. Timecode display on diff device has delay Quote Link to comment Share on other sites More sharing options...
Lucan Posted May 3, 2020 Author Report Share Posted May 3, 2020 Hey all, my apologies for the late reply- I was MIA there for a bit! On 4/20/2020 at 6:59 AM, evarsimon said: I do something similar, except my TC comes out of a Maxx into the IFB board of a QRX235, might just be the display. I run 3 cameras often and I also edit, and the sync is not off. I think you're workflow is basically the same as mine (only major difference is the Maxx), so thats great to know! On 4/20/2020 at 8:17 AM, sciproductions said: Just out of curiosity, when you put it on free run does it do the same thing? I.e. 2 frames off? On the RX200 have you checked your Zaxnet settings that there isn't timecode frame offset? The first time I noticed this discrepancy was when I put it on rec run for a particular job. Normally I work in free run with multi cams and so far I haven't had any comments/complaints from post. All the settings seem to be set properly on all the devices, no offset on the ERX's. I'll do as @joinwooHK suggested and record a beep in all timecode modes. On 4/22/2020 at 2:35 AM, joinwooHK said: i suggest u Record a beep to all and see is it there offset on recorded file. Timecode display on diff device has delay Thanks mate, i'll test this out and post the results. Yeah I thought each display might be different. Thanks guys! Quote Link to comment Share on other sites More sharing options...
