telpauli Posted July 8, 2020 Report Share Posted July 8, 2020 Power distro box is the NPC-SQN4 Hawkwoods Shoe, using SWIT S-8073N batteries to power some RX units and a 788t w/ CL9. Very strange issue with one of the batteries on a job this week, wondering if someone with more know-how may shed some light on this: Fully charged and inserted into shoe, with corresponding switches on, the battery can power the RX units with no issue, but isn't recognised by the 788t (which is powered by main cable out of shoe - RXs connected to shoe with 4-pin HIROSE to 4-pin HIROSE cables). Only one battery does this, all other NP1s power it no problem. I've checked inside, checked the connectors, tried it with a different shoe and same issue. One further note is that the battery seems to charge to full much quicker than usual. Anyone had a similar issue? Something I can fix myself or do I need to send it away? Quote Link to comment Share on other sites More sharing options...
Constantin Posted July 8, 2020 Report Share Posted July 8, 2020 What’s the voltage coming out of the main plug? Did you measure it? Quote Link to comment Share on other sites More sharing options...
telpauli Posted July 8, 2020 Author Report Share Posted July 8, 2020 I checked the voltage output on recorders (633 and 788t), but not recognised so did not get a reading. I don't have a voltmeter, but can borrow one. Anything in particular I am looking for? Thank you for your reply. Quote Link to comment Share on other sites More sharing options...
Sound Grab Posted July 8, 2020 Report Share Posted July 8, 2020 What's the 788T low voltage setting at? Then what's the voltage coming from the battery at? Quote Link to comment Share on other sites More sharing options...
telpauli Posted July 8, 2020 Author Report Share Posted July 8, 2020 2 minutes ago, Sound Grab said: What's the 788T low voltage setting at? Then what's the voltage coming from the battery at? 788T low voltage set at 11.3. Battery not recognised by device.. Quote Link to comment Share on other sites More sharing options...
Constantin Posted July 9, 2020 Report Share Posted July 9, 2020 If it’s only that one battery it seems likely like that one is broken. Possibly is giving out a voltage that is lower than 11.3 and that explains why your rx can work with it, but the 788 won’t. Are the other outputs regulated? What happens if you hook up the 788 to one of those? Quote Link to comment Share on other sites More sharing options...
