Jason Nightall Posted July 15, 2020 Report Share Posted July 15, 2020 Here in the UK we are limited to 50mw power output on our transmitters whereas in the US and other countries the limit is 100mw or 250mw So my question simply is how much real world difference will it make to go over 50mw assuming I’m using a bag receiver with whip antennas? Quote Link to post Share on other sites
daniel Posted July 15, 2020 Report Share Posted July 15, 2020 16 minutes ago, Jason Nightall said: Here in the UK we are limited to 50mw power output on our transmitters whereas in the US and other countries the limit is 100mw or 250mw So my question simply is how much real world difference will it make to go over 50mw assuming I’m using a bag receiver with whip antennas? The laws of 'Diminishing Returns' and 'Marginal Gains' apply. Lectro and Wisy RX conveniently allow operators to use higher powered Lectro TX when circumstances allow for and require such. Quote Link to post Share on other sites
RocketTreeAudio Posted July 15, 2020 Report Share Posted July 15, 2020 In my opinion antenna choice and placement does more than output power on Tx. with that said though, 250mw with car to car stuff helps. Quote Link to post Share on other sites
r.paterson Posted July 15, 2020 Report Share Posted July 15, 2020 I am in the uk and i have switched 50mw/100mw and 250mw transmitters i have dipoles on my harness..i use 50mw 99% of the time except when in boats and transmitting across water or rock climbing and i switch to 100mw, if using more than x 4 radios i would never switch to 100mw whatever but stay at 50mw or intermodulation goes out the window if all on 100mw, so unless accross water or bouncing of rocks 50mw is your best friend..the answer is in minimising any tx hop/iem hash in bag etc..hence my receiver dipoles are on my harness.. Quote Link to post Share on other sites
Mark LeBlanc Posted July 16, 2020 Report Share Posted July 16, 2020 250mw is the only way I can get past all the garbage Camera/Crane setups put out... 100mw just get's caught in the wash.. Quote Link to post Share on other sites
BAB414 Posted July 16, 2020 Report Share Posted July 16, 2020 Apparently for digital, lower power output gives as good range as higher power on analogy/hybrid wireless. The new DPR can do 25 or 50mW. For my normal SMQV/Venue2/srB setup, I'll run all 8 channels at 100mW with minimal problems (I'm in NYC). I'll set transmitters to 250 for exterior walk and talks and some moving car stuff but I haven't had any major issues working this way. Quote Link to post Share on other sites
Trey LaCroix Posted July 17, 2020 Report Share Posted July 17, 2020 On 7/15/2020 at 1:37 PM, r.paterson said: if using more than x 4 radios i would never switch to 100mw whatever but stay at 50mw or intermodulation goes out the window if all on 100mw I used 16 lectros on 100mw for a show last year and had no noticeable intermod issues. (I coordinated of course). Quote Link to post Share on other sites
r.paterson Posted July 17, 2020 Report Share Posted July 17, 2020 3 hours ago, Trey LaCroix said: I used 16 lectros on 100mw for a show last year and had no noticeable intermod issues. (I coordinated of course). In uk we have to use mainly between 606 and 613 mghz so thats where after 4 x units at 100mw you can get intermod. You can squueze in a couple more at 50mw.. Quote Link to post Share on other sites
VAS Posted July 17, 2020 Report Share Posted July 17, 2020 50mW here, Greece. Very rare to go 100mW, but sometimes is necessary. Quote Link to post Share on other sites
Trey LaCroix Posted July 17, 2020 Report Share Posted July 17, 2020 8 hours ago, r.paterson said: In uk we have to use mainly between 606 and 613 mghz so thats where after 4 x units at 100mw you can get intermod. You can squueze in a couple more at 50mw.. YIKES! And I thought we had it bad in LA. Quote Link to post Share on other sites
RocketTreeAudio Posted July 17, 2020 Report Share Posted July 17, 2020 I leave all my ZMT3s at 75mw no issues so far. Quote Link to post Share on other sites
ramallo Posted July 21, 2020 Report Share Posted July 21, 2020 On 7/15/2020 at 4:07 PM, Jason Nightall said: Here in the UK we are limited to 50mw power output on our transmitters whereas in the US and other countries the limit is 100mw or 250mw So my question simply is how much real world difference will it make to go over 50mw assuming I’m using a bag receiver with whip antennas? No, +3dB in 100mW vs 50mW (Isn't a big difference) and +7dB 250mW vs 50mW, this is a nice difference, same amount as out of polarization vs right polarization (But the difference in consumption would be huge) On 7/16/2020 at 3:13 AM, BAB414 said: Apparently for digital, lower power output gives as good range as higher power on analogy/hybrid wireless. The new DPR can do 25 or 50mW. According to its advertising, the digital radios can work with less signal to noise ratio in RF, this would be the reason Quote Link to post Share on other sites
