Lectrosonics Venue 1 antenna power switch mod?
Has anyone here done this mod themselves and be up for offering any ideas or tips?
 I’d love to get two toggle switches on the front of a venue to switch antenna power in and out but probably putting them on the rear panel would be easier.
And here’s a dumb question.. While drilling through the case how do you keep metal cuttings from falling all over and into the circuit board? I know the painters tape trick which contains it to some degree. I suppose you could completely remove the boards but with my luck I’d probably break something in the process.
Side question if Larry happens across this... if I use an illuminated switch does enough voltage and current pass through the antenna jumper to actually light an illuminated switch?
  • 2 weeks later...
Some ways (depending largely upon your access inside the chassis) --
1) Cover the circuit boards with paper, taped in a way that serves to seal them off
2) Use a vacuum to suck up the cuttings as you drill
3) Form a "containment cup" taped to the chassis behind the hole you're drilling
You could possibly combine 1&2 or 1&3.
