Has anyone here tried this? I know some companies do this for you, but for me it would be way to expensive to send this abroad. So I'm courious to see if anyone has done this and wants to share their experience.
18 hours ago, humbuk said:
I had a lemo cable made on sma.
That is the right way to do this! You do not happen to have some kind of instructions for that our a pinout map or something similar?
Connection is very easy, there are only two pins - hot and ground :). But it's not easy to get that Sennheiser lemo connector and you need a special crimp tool. So I had the cable made in Sennheiser.
Thanks humbuk!
That I have found out! Well have found a straight connector but not 90° one, can I ask you, did you manage to get angled ine or is it straight? Just wondering here how much time I should spend on finding one.
Thanks,
Björn.
