Trouvier Posted October 27, 2020 Report Share Posted October 27, 2020 Hello everyone, I was wondering if any one of you ever tried to power their SD633 recorder, HFs, etc. via a usb powerbank, since these are incredibely cheap compared to other power sources. I just stumbled upon these usb/hirose cables on Amazon and was wondering if this would work: https://www.amazon.com/Eonvic-Hirose-Power-Devices-Recorders/dp/B08B4QRRXR/ref=sr_1_1?dchild=1 Any thoughts? about voltage, intensity? My electric knowledge is really nonexistent... In my bag is a SD 633, a Wisycom MCR42 and a Sonosax SX-M2D2. They all have hirose power in. Thanks by advance for your help! Quote Link to post Share on other sites
Derek H Posted October 27, 2020 Report Share Posted October 27, 2020 I would recommend buying even used professional NP1s before going this route. But yes, it would probably work. Quote Link to post Share on other sites
Allen Rowand Posted October 27, 2020 Report Share Posted October 27, 2020 Another option would be something like these Talentcells: https://www.amazon.com/s?k=talentcell&crid=YO3GHYXIA1CZ&sprefix=talentc%2Caps%2C219&ref=nb_sb_ss_i_1_7 I've been using them for over a year with no issues. I'm not recommending them over a professional battery system, but I'd much rather use these than a USB step-up cable. Quote Link to post Share on other sites
Mungo Posted October 27, 2020 Report Share Posted October 27, 2020 As long as the audio connection to your other USB bank powered devices (wireless receivers / transmitters) is balanced, this will probably work. Otherwise you will most likely get some dc/dc transforming and ground related noise. Quote Link to post Share on other sites
Derek H Posted October 27, 2020 Report Share Posted October 27, 2020 At least find a power bank that operates at 12 volts. Otherwise you’ll be losing some efficiency to the boost converter. The RF/EMI noise could be a real issue. Quote Link to post Share on other sites
daniel Posted October 29, 2020 Report Share Posted October 29, 2020 On 10/27/2020 at 5:07 PM, Trouvier said: Hello everyone, I was wondering if any one of you ever tried to power their SD633 recorder, HFs, etc. via a usb powerbank, since these are incredibely cheap compared to other power sources. I just stumbled upon these usb/hirose cables on Amazon and was wondering if this would work: https://www.amazon.com/Eonvic-Hirose-Power-Devices-Recorders/dp/B08B4QRRXR/ref=sr_1_1?dchild=1 Any thoughts? about voltage, intensity? My electric knowledge is really nonexistent... In my bag is a SD 633, a Wisycom MCR42 and a Sonosax SX-M2D2. They all have hirose power in. Thanks by advance for your help! Hey Trouvier, In my experience Power Banks are not significantly cheaper than np-f 'L' batteries (per Wh). 'L' batts fit directly to 6 / 8 series recorders and some have USB I/O. Very versatile. The USB to Hirose cables are a good idea to have in back up or for a static rig but as secure as the Hirose end of the cable is, the USB end of the cable isn't and USB panel connectors get easily damaged. I use a HW battery mount in my bag to O/P 12 volts if needed from L series batteries and many bag devices will work from 7.2 anyway (eg MCR42). For c. cost of 1 Audioroot 96Wh battery you can buy nearly 6x 56Wh L series batteries - 3 times more power, 6 times more redundancy and you can double all those numbers as real world usage means you need at least 2 batteries packs (however good the brand is) as it would be 'suicide' otherwise. PBs are cheap but as your primary powering you are committing to a system totally reliant on a flakey connector. As a BU it's very good value though. https://www.amazon.co.uk/dp/B07RC1TG2B/ref=sspa_dk_detail_4?psc=1&pd_rd_i=B07RC1TG2B&pd_rd_w=zwmPD&pf_rd_p=1055d8b2-c10c-4d7d-b50d-96300553e15d&pd_rd_wg=mUl7S&pf_rd_r=89S995Y486R5N6M2GXYP&pd_rd_r=0436e4db-5fbe-49f9-ad5f-b8ca8073dfce&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEySEgxSklNSkE2WFlEJmVuY3J5cHRlZElkPUEwODU0NDA5MVZXNzlQWkE1WU5MSSZlbmNyeXB0ZWRBZElkPUEwMjM3Njg1OFVUOVZIRENLVTFOJndpZGdldE5hbWU9c3BfZGV0YWlsJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ== Quote Link to post Share on other sites
