Snyderman Posted December 8, 2020 Report Share Posted December 8, 2020 I recently purchased a used COS-11 that works only on my older, non-backlit SMQV's and SMV's. In terms of gain it's pretty identical to my other COS-11's, though it does sound a bit different. On my newer, backlit SMQV's and SMV's, it's just static and popping. I had similar results with my um400 and um400a; the microphone worked perfectly with the 400, but was much quieter and fuzzy on the 400a. Could this have to do with the wiring? I've read a lot about servo bias vs universal wiring with regards to the um400 vs 400a, but is this also an issue with the SMQV/SMV? Quote Link to comment Share on other sites More sharing options...
Dean Slotness Posted December 8, 2020 Report Share Posted December 8, 2020 Wiring is the most likely suspect in this case. Verify that the Sanken COS-11 is wired as shown in figure 5 of the following: https://www.lectrosonics.com/Support/Microphone-Wiring/uhf-transmitter-5-pin-input-jack-wiring.html Quote Link to comment Share on other sites More sharing options...
Snyderman Posted December 9, 2020 Author Report Share Posted December 9, 2020 I just opened it up, and yes, it is indeed wired as shown in figure 5. Quote Link to comment Share on other sites More sharing options...
