Erin Bliss Posted December 8, 2020 Report Share Posted December 8, 2020 What are these little foot-capturing-mount-plate things called? Quote Link to comment Share on other sites More sharing options...
osa Posted December 8, 2020 Report Share Posted December 8, 2020 is it possible a form of a cold she mount? hard to tell but search brings up slightly similar looking items https://www.google.com/search?q=cold+shoe+mount+plate&client=firefox-b-1-d&sxsrf=ALeKk03vUMZPfLhrpTpNBQlZiA-7tDRZtw:1607464515373&source=lnms&tbm=isch&sa=X&ved=2ahUKEwiS3bX7r7_tAhUTElkFHSRHDgkQ_AUoAnoECA4QBA&biw=1366&bih=643 Quote Link to comment Share on other sites More sharing options...
Paul F Posted December 8, 2020 Report Share Posted December 8, 2020 It's hard to tell from that photograph as the size isn't obvious, but it reminds me of a microphone hang-up clip. https://www.google.com/search?q=microphone+hang+up+clip&client=firefox-b-1-d&sxsrf=ALeKk01kwzcfmKbxUnr29CQsh1ctHQ_5UA:1607465336078&tbm=isch&source=iu&ictx=1&fir=i_Zd_IppnqvDyM%2CdSmwsQbFqahr9M%2C_&vet=1&usg=AI4_-kSHaGJjm-8lUi8DzBFJJKKIPMjVhQ&sa=X&ved=2ahUKEwi7xuGCs7_tAhXPvZ4KHX6XAHkQ9QF6BAgJEAE#imgrc=i_Zd_IppnqvDyM Quote Link to comment Share on other sites More sharing options...
PMC Posted December 9, 2020 Report Share Posted December 9, 2020 Breaker 1 9. That looks like a two-way radio or CB radio mic hanger. Dash board mount. Quote Link to comment Share on other sites More sharing options...
Erin Bliss Posted December 9, 2020 Author Report Share Posted December 9, 2020 Specifically this is a close up of one of the upper corners on the Aaton "Cheese Plate" for the Cantar Mini. I'd like to find the receiver plates they're using (yes, I could email Aaton but I thought I'd ask around first). Quote Link to comment Share on other sites More sharing options...
Paul F Posted December 9, 2020 Report Share Posted December 9, 2020 That cheese plate receiver looks just like a mic hanger. Here is the other half of a mic hanger, the 'button' that you may be looking for - https://www.rightchannelradios.com/products/replacement-hanger-button Quote Link to comment Share on other sites More sharing options...
Erin Bliss Posted December 14, 2020 Author Report Share Posted December 14, 2020 Thanks all! Drpro mentioned in his DIY thread that he had sourced some directly from Aaton, and while I still have no idea what they're properly called I've found a dartboard hanging kit on Amazon that includes an exact-fitting plate. Quote Link to comment Share on other sites More sharing options...
drpro Posted December 14, 2020 Report Share Posted December 14, 2020 Neil I just sent a photo to Pierre. I didn't know what to call it either. I do think the microphone clip idea might work. Just remember the underside of the Mini is not uniform, hence the left and right shapes of the clips. They appear to be made from stainless steel and are perhaps 2-3mm thick. I do trust the 3/8" mounting screw, but the clips keep the Mini in place. Just my 2 cents Quote Link to comment Share on other sites More sharing options...
Erin Bliss Posted December 14, 2020 Author Report Share Posted December 14, 2020 That's pretty much my thought process as well, the mounting screw will do the bulk of the work, but I'd like the clips up front to help out a little and keep the unit located. I did a little bit of a test fit on the pieces I found, and they look like they'll work but may need a little trimming to work around the specifics of the Mini's underside. Quote Link to comment Share on other sites More sharing options...
