saadasound Posted January 12 Report Share Posted January 12 I'm interested in upgrading to a dante system and was wondering if anyone had any recommendations for certain dante workflows? How do you incorporate the system into your cart? Anyone using a remote setup running out to set? Pictures of setups maybe? Thanks so much!!! Steve Quote Link to post Share on other sites
S Harber Posted January 13 Report Share Posted January 13 Hi Steve, I remote my Venues in a rack that goes to set and keeps me away from the density of the area around set. It also helps us not have to run antenna cable and has it's own battery and power supply. My Cantar has Dante and I can run the outputs of the receivers to a Ferrofish converter that makes the analog outs of the Venues into Dante which then cables back to my mix cart. The Dante runs seamlessly and we unplug it and rearrange it many times each day. I've managed to get the telemetry of the Venues to run in WirelessDesigner as well via a USB to IP converter which then goes to my laptop. The schematic is attached and there's plenty going on including power and a feed back to the rack for an IFB transmitter etc. SH Set Forward.numbers-Routing.pdf Quote Link to post Share on other sites
